Eerste Waterkoeling €500 / €200
Hehe yes I tried all of them myself.
Now I have tried to get the loop working , but I can hear the water flushing in the pomp but when I look at the slangen theres only water halfway thru them. The slang from the reservoir which is going to the pomp seems to be almost empty. Thought I knew how to connect a water cooling system but I doubt myself now hehe.
Reservoir is connected on the back of the case. Pomp on the case floor and radiator on the front. I have filled up the reservoir almost full. Maybe theres something wrong with the pomp or I didnt connect the slangen to the correct spots? I maybe need a full explanation...I feel like a noob now haha. (I have read the advices you have here on the forum)
Ok heres my darling hehe. Well it looks like a mess I know, but I just want to try the loop and see if theres any leaking. So its not completed yes.
The radiator is on the rechts side on the front. Maybe hard to see were all the slangen goes.
My reservoir has 4 in/out puts. I use the ones on the bottom/lower.
On the pomp I use the in/out on the side\front which you should be able to see on the pictures.
Also I think I will get myself a better case. Maybe You nice people can give me a good advice on a new case too? It has to fit all my things good. Prize dont matter.
I use a metal pin between the green and black on the atx power supply just to make it run the water loop. Not the MB itself.
Oh thats a good idea. Ill get to it right away!
Added after 49 minutes:
Ok Ive tried to turn the case in all directions still not enough.
I have 2 fotos attached with the new reservoir place.
Maybe ive connected the slangen wrong on the pomp?
Now im writing from my OWN computer WITH WC :) Ive just connected everything like its supposed to be. It all works very nice. Almost 10 degrees cooler then before. Im at 3,7 ghz atm, but now I can go higher.
Ill get more cash and get more moddings and a nice new case (from Highflow ofc!). Think I need a new one cuz some cables and things are abit to tight imo.
So once again DANK U WEL for all the help and advice You gave me!
Groetjes
Per
Im back and now Im going to order the Silverstone TJ07BW :) Also Im going to change my slangen to 13mm. But is it Tygon R3603 - HighFlow - 1/2 ID - 3/4 OD - Clear or is it Tygon R3603 - HighFlow - 1/2 ID - 5/8 OD - Clear I should buy? The bigger the better? Then Ill need the correct fittings for it. Wanna have the clear slang so I can use UV liquid and UV licht to it.
Maybe this is a bit crazy cuz Ive had the WC for just a week or so, but I really wanna get a better case so I can get cables and such in a more nice setup.
R EErste waterkoeling bouwen Waterkoeling 16
C eerste waterkoeling Advies Waterkoeling Setup 5
B Eerste waterkoeling systeem Advies Waterkoeling Setup 3
O eerste waterkoeling Advies Waterkoeling Setup 14
B Eerste keer waterkoeling 800euro i5 3570K+ GTX670 Advies Waterkoeling Setup 6
D Eerste stappen met waterkoeling Advies Waterkoeling Setup 17
H Eerste Waterkoeling Set, Advies Waterkoeling Setup 20
E Eerste Waterkoeling Advies Waterkoeling Setup 1
N Advies eerste waterkoeling. Advies Waterkoeling Setup 15
focus08 Eerste OC met waterkoeling Overclocking 5
Tomas Eerste keer waterkoeling Waterkoeling 12
W eerste waterkoeling Advies Waterkoeling Setup 42
