Eerste Waterkoeling €500 / €200
Now in the middle of the night Ive just setup my new Silverstone case with 13mm tubes, UV light and UV (blaue)feser liguid :) Works very good!
A few questions.
The blaue feser liquid is a bit foamy. White on top of the blue liquid. Is something wrong with it or wat is it? Its streaming fine in the tubes what I can see tho.
The UV licht was supposed to be bright blue but its purple. Maybe I got the wrong licht?
Anyways Im very happy with this setup and I will take pics tomorrow and show you all.
SLaap lekker!
The foam will go away. I'm not sure how long it will take, but it will go away. Some set-ups have that foamy effect with the (pre-mixed) water in the beginning.
Strange about that purple color. :hmm
UV lighting is always purple with a tiny (very tiny) blue shade. But is the liquid lit in blue? Or also in purple?
If you need real blue lightning inside your case and still want the UV liquid to be blue litted then i will suggest you to use UV lightning and additional blue ledstrips or blue neon tubes for a tighter look.
Best is then to place the UV lighting not in direct sight and the blue lightning there were it generates the best effect for you (just don't mount them somewhere, but use different angles and positions untill it's good enough for you).
Ok so then I will see the *foam* go away soon. Not that its any big issue just looked abit strange. Yes I know the UV licht is purple and as you said I may have to get another UV licht or change the mounting angle of the UV.
Heres 2 pics from the new build. Im satisified with it compared to my eerst :)
If you want the case lighting to be blue, then i suggest that you put some neon or ledstrips on the sidepanel with window. Not directly on the side of the window, but a bit further from the window so you won't look directly into "the sun" ;).
It's the most effective way to enlight your entire case, but still won't be totally blinded by the lights when you look through the window.
Good luck ;).
R EErste waterkoeling bouwen Waterkoeling 16
C eerste waterkoeling Advies Waterkoeling Setup 5
B Eerste waterkoeling systeem Advies Waterkoeling Setup 3
O eerste waterkoeling Advies Waterkoeling Setup 14
B Eerste keer waterkoeling 800euro i5 3570K+ GTX670 Advies Waterkoeling Setup 6
D Eerste stappen met waterkoeling Advies Waterkoeling Setup 17
H Eerste Waterkoeling Set, Advies Waterkoeling Setup 20
E Eerste Waterkoeling Advies Waterkoeling Setup 1
N Advies eerste waterkoeling. Advies Waterkoeling Setup 15
focus08 Eerste OC met waterkoeling Overclocking 5
Tomas Eerste keer waterkoeling Waterkoeling 12
W eerste waterkoeling Advies Waterkoeling Setup 42
