Temperatuur te hoog met mijn waterkoeling set?
Ik heb mijn cpu blok nog een beetje harder vastgeschroefd en dat bleek te helpen.
Ik zit nu op 30°C idle (realtemp).
Op 3.3ghz full load heb ik 49-52°C
Ik heb dan eventjes een 3.8GHZ oc geprobeerd maar dit lukte gewoon niet.
Zodra windows startte kreeg ik een BSOD.
met de volgende settings in mijn BIOS:
Code:
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Enabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[181]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1451MHz]
UCLK Frequency.........................[2903MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.16875]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.20000]
IOH Voltage............................[1.14]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Enabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Enabled]
bah, dat wordt dus tweaken. Ik hoopte op easymode 4gzh :D
Code:
hoop code
Speedstep moet afstaan en uw Vcore is te laag voor die speeds ;)
Code:
hoop code
Probeer eens:
Code:
CPU Ratio Setting......................[u][18.0][/u]
Intel(r) SpeedStep(tm) Tech............[u][Disabled][/u]
BCLK Frequency.........................[u][200][/u]
PCIE Frequency.........................[u][101][/u]
DRAM Frequency.........................[u][DDR3-1600MHz][/u]
UCLK Frequency.........................[u][3200MHz][/u]
CPU Voltage............................[u][1.25000][/u]
CPU PLL Voltage........................[u][1.82][/u]
QPI/DRAM Core Voltage..................[u][1.3000][/u]
IOH Voltage............................[u][1.12][/u]
ICH Voltage............................[u][1.10][/u]
CPU Clock Skew.........................[u][Auto][/u]
C1E Support............................[u][Disabled][/u]
CPU TM Function........................[u][Disabled][/u]
Intel(r) C-STATE Tech..................[u][Disabled][/u]
Met gelijke settings draaide ik al 7 maanden op 4.2Ghz op een IFX-14 met 2 fan's op 7V. En ik deed er alles mee...
Weliswaar met iets hogere VCore (duh :p ).
EDIT:
Het onderlijnde heb ik veranderd :).
oplopende temperaturen
ik heb pas geleden bij highflow.nl een waterkoeling bestelt de xspc x2 delta 4 kit
ik heb hem geinstalleerd volgens het boekje maar de temperaturen blijven maar steigen.
iemand een oplossing?
Zou je ons wat meer info kunnen geven? (hardware, case, fan opstelling...)
En misschien een paar foto's zodat we kunnen nagaan hoe je alles geinstalleerd hebt?
Uploaded with ImageShack.us
dit zijn wat plaatjes ^
mijn specs:
amd phenom II x4 black edition 3.2ghz
ati radeon hd 5770
4gb werkgeheugen ddr3
ik vind dit zeer hoog omdat de cpu maar 02% gebruikt, de 44 graden was toen ik pc net aanzette maar toen schoot hij al gelijk omhoog naar 60 graden.
ik heb er al een andere ventilator opgezet want de bijgeleverde ventilator had 1700 rpm en de nieuwe 2400rpm maar er zit niet veel verschil in temperatuur.
hopelijk hebben jullie hier genoeg aan en anders hoor ik het wel.
De kant waar de fans hun "steunen" hebben daar blazen ze. Echter maakt het normaal niet uit hoe je de fans op een radiator plaatst. Je kan hem zo zetten dat hij de lucht erdoor trekt (pull) of dat hij lucht erdoor perst (push).
Velen gebruiken dus ook push/pull tegelijk omdat dit vaak nog iets meer winst kan opleveren...
Het maakt niet veel uit of de fan er doorheen blaast of zuigt.. mss 1 a 2 graden.. EDIT: Beta was hiermee al voor
Draait je pomp wel... stroomt het water door de slangen heen??
Ben je vergeten het plastic beschermplakkertje van de cpu blok te halen (kan gebeuren heb ik ook ens gedaan)
Zit er nog veel lucht in je rad??/ op de manier hoe je rad is aangesloten kan het zijn dat je rad nog veel bevat..
ja het water stroomt er door en ook het berschermkapje is weg want dat was het eerste waar ik aan dacht toen ik die temperaturen haalde. en als er lucht in mijn rad zit hoe haal ik dat eruit?
ok ik zal het is gaan proberen
godverark!! daar kwam veel lucht uit :O de temperatuur is nu langzaam aan het aflopen momenteel is hij 42 graden echt bedankt voor die tip! hopelijk word hij nog wat kouder.
water temp. beetje aan hoge kant?
Hallo,
ik zag vandaag dat de tempratuur van me water redelijk hoog (vergeleken met omgeving) word
specs PC (Watergekoelde delen dan)
Phenom 955 II x4 Black @ 3,2GHZ -> watercool Heatkiller rev3.0 (d8 ik)
8GB corsair dominator 1600MHZ (4x2) -> mips ram freezer pom corsair editie
Pomp(je) MCP 350 met xspc res top.
Rad, xspc 360 rad
fans: push: 3x antec tricool (laagste standje, hoogste scheelt 1 graad)
shroud, technofront rad box 360 (freddy heeft hem ook in de shop)
pull fans: 3x scythe sflex 1900rpm @ 7 volt ongeveer (ze draaien zachtjes)
ook een rad box 360 shroud ertussen
Me water temp: 29.1
CPU temp 34.3-35.7
omgeving 18-20
load, water 32-33
CPU 40-41
omgeving nog steeds 18-20 (de rad staat extern)
ik gebruik feser one UV blue koelvloeistof, en volgens mij is hij voor 99.9% ontlucht.
ik heb geen flow meter dus kan het niet goed zien.
Kan het door de rad boxjes komen? (minder druk op rad?)
iemand ideen? ik hoor het graag.
Binnenkort ga ik de pomp vervangen door een laing D5, en komt alles mooi intern in een corsair obsidian 800D kast.
ik hoop dat het dan over is en ik mischien de GPU's later ook kan koelen.
Ik hoor graag wat jullie ervan denken.
mvg,
adriaan.
T Temperatuur Waterkoeling 1
S Op basis van temperatuur cpu, pomp laten aanslaan Waterkoeling 6
Robert Temperatuur verschil h80i en custom loop voor Ivy bridge Waterkoeling 1
S Temperatuur Radeon HD 7970 Watercooled Waterkoeling 4
C Temperatuur display cijfers knipperen... Problemen & Oplossingen 0
O Temperatuur panel Overige Builds 2
Roedi Hoe water temperatuur verlagen? Overclocking 16
P Temperatuur meten wc koeling. Waterkoeling 2
N Temperatuur loop goed? Waterkoeling 15
Marcel2102 temperatuur sensor delen Electronica 14
F Water/cpu temperatuur Waterkoeling 38
S Water temperatuur sensor / Single - parallel water loop. Waterkoeling 7
D 2-Pin verlengkabel voor moederbord (power knop, temperatuur sensor etc.) HighFlow Product Suggesties en Nieuws 6
Blackruby Temperatuur sensor plaatsen/vastmaken. Handleidingen en Installatie Tips 6
M Temperatuur CPU, anders in Coretemp dan in BIOS Overige Koeling 20
X Temperatuur en flow gemeten met TMS200 Waterkoeling 9
X Temperatuur sensor calibreren Waterkoeling 7
X (te) lage temperatuur Waterkoeling 38
R IOH temperatuur MSI x58 pro Waterkoeling 6
nootje NB/SB temperatuur Overclocking 14
Craven temperatuur meter? HighFlow Product Suggesties en Nieuws 4
P temperatuur Waterkoeling 9
R Temperatuur Lucht meten. Overige Koeling 2
X Temperatuur CPU Waterkoeling 6
V Hoe meet je de juiste temperatuur van een 45nm processor Overclocking 9
M Water temperatuur Waterkoeling 7
H Dell Poweredge 2950 CPU 0 usage hoog Problemen & Oplossingen 2
R Temps weer lekker hoog. Waterkoeling 14
Jamoru WC temps E8600... te hoog of goed? Waterkoeling 31
Craven temps te hoog? Overige Koeling 57
