[Project Log] "Parvum|Beast" - Semi Sponsored Build
The Liquid & Light Test​
Okay so first i tried both the UV Blue and the Blood Red Ekoolant in a few blocks, and i really like both colors alot.
But then i put it under light, "sorry for the low quality, hard to catch the real life colors on camera".
and i tried all kinds of colors, and ended up with white or dark blue as favorites "Last 2 images".
Also I am now pretty sure that i wont be using the Blood Red, just reacted really bad under all the lighting.
What do you guys think? and again sorry for the poor image quality with lights on.
I personally think the blue liquid reacts really nice under light, and think it will be dark blue or white led, "Last 2 images".​
yeah i went full on uv on my pc and it's a bit all purple and black exept my white sleeved cables that shine and stand out so much lol:d might paint some part to get some matching white into my build
Installing the waterblocks Part 1​
Here's the first part of waterblock installing, as you might notice i did not install the monarch x4 block on the memory yet, i will do this in a later post, when i mount the blocked mobo into the case :) pics will follow!
Absolutely LOVE the look of the CSQ blocks from EKWB, when they are polished! <3​
Installing the waterblocks Part 2​
Theese polished blocks just look so amazing ! cant wait to see it all with liquid in it ! <3
You might notice that after i blocked the pump and put on the nickel housing, I just HAD to sleeve those cables,
i am NOT a fan of the original black,blue and yellow cables :D So i took my time and sleeved them in the colors i will be using in the build later on.​
Test Mounting of the Waterblocks, and modding the flipped GPU. Part 1​
Allright, got alot of work done last few days. Test mounted the blocks to see how it looked best,
then flipped the gpu, bend some acrylic sheets to act like supporters for the gpu, and added some velcro tape to hold it in place.
after that, it was time to figure out how i wanted the cut in the case and pci slot cover to be.
Then after the cut i saw i cut too big of a hole, but still its okay :)
I also was thinking alot about the pump placement, if i wanted it next to the 120mm rad, mounted in the back at the mobo tray, or where
to put it for the best looks..
Then i thought maybe i could make another acrylic piece bended in the angle of the GPU, so that the Pump actually is tilted in same angle
as the GPu, and i must say it's got the look i was hoping for :) ..
Also cut out a hole for the LCD temperature display..
But still awaiting the final piece from Parvum, so maybe i will change it later or redo it,
but for now it works out great i think :)
I also drilled holes for the reservoir mount, and shot a few pics with everything in its place, and also with the window on to see how it
looked :)
So what do you think guys ? .. next up will probably be installing fittings and tubing and figuring out the loop :)
Test Mounting of the Waterblocks, and modding the flipped GPU. Part 2​
I also was thinking alot about the pump placement, if i wanted it next to the 120mm rad, mounted in the back at the mobo tray, or where to put it for the
best looks..
Then i thought maybe i could make another acrylic piece bended in the angle of the GPU, so that the Pump actually is tilted in same angle as the GPu, and i
I also drilled holes for the reservoir mount, and shot a few pics with everything in its place, and also with the window on to see how it looked :)
Just had to try this since its a monster blue energy inspired build :D
So i just finished my Moster Blue Energy Drink, and decided maybe i should cut it and try to fit it over the reservoir, as a reservoir sleeve :D .. And i have to say, i actually think it looks kindda awesome.. Maybe i should try do mod it a bit, and see if i can cut out the logo and
make the "M" light up with the UV blue liquid in the res ?
So what do you think guys ? ..worth doing, or just looks to lame ? .. Keep in mind i have monster logo on case also, and that this build is a monster tribute build to the blue energy drink that i love so much :)
I miss UV lights?
Ooh, i've got a lot of lighting for this case :D
8M RGBW Led strips, and alot of uv strips, cathodes and leds :)
Will put up a ton of pics when i install the lighting as one of the last things :)
But will install the RGBW strips first, because after alot of tests i've done, it looks like the blue/purple color from the RGBW actually illumintates the UV Blue liquid just as good as the uv light it self does :)
UPDATE: The fans and the rest of the sleeving just arrived <3<3 ..
Will take images of it monday where i will also try to cut out the monster energy drink can, and see if i can make it beautiful as reservoir sleeve,
or if i have to try something else :)
The Fans, Silverstone AP121 Uv Blue Blades​
So the new fans just came in ! The Silverstone AP121 with Uv Blue Blades <3 ..
Originally i was going for the other version with blue led and transparent blades, and silver housing. But after trying them out i disliked it
alot.. NOT the fans themselves, but only the way it fit my color theeme.. So obviously i had to get the black housing ones with blue blades instead,
and i am pretty sure it will look sweet with uv blue blades along with the uv blue liquid from ekwb :)
Also i tried to mount them on the EK Radiators, as a temporarily solution.. just to see how it looks..
Will take them off again later when i re-sleeve the wires from them :)
Love how it looks.. Tho i know i HAVE to re-sleeve the fan wires, looks okay from stock, but thats just not good enough for me :)
Pictures of all sleeving progress will follow very soon guys !​
