[WorkLog] Project Scarlet|Ti
kmp-cooling
Small UP!
As you can see I had to move the cage inside of HDD, for reasons of space, since in the front I will install a radiator 360! I think I do later the holes. because those in case are not useful; so I can place the port HDD to a fair distance between the radiator and the power supply!
Now beginning to mask all the pieces and then paint it!
All for now! Stay tuned! :D
Other UP!
Finally paint! I used a red metallic paint which comes closest to the Red Scarlet, I hope to look good color! Unfortunately from the photos the color is not exactly what it seems!
When I'll finish the work, I will do the photos with reflex and lights!
I really like the color, I don't know you! Let me know! :023:
Thanks! :D
Here is a Big Up as I promised! :D
I unplugged, with the hair dryer, the label from hdd, I took me some time to not throw too much heat on the HDD, then to soften the glue have been there a good 5 minutes!
Then I put on the kit box of screwdrivers, the adhesive because I didn't know which on the surface to keep it for not to make him completely lose adhesiveness :)
I masked the HDD to paint it quietly and then cut the upper ribbon with the cutter precision to cover only the part in relief and the inputs of the screws! Getting what you see in the picture above!
Here I gave a primer because it did not take paint well, in fact I had to removing paint and do it again!
Black paint!
That's what I obtained! The edges could not come better than this! Then I touched up by hand with a brush and paint spray!
Now it masks the contrary! And so red!
Here cutter precision I gently removed the tape paper after first warmed a bit with the hair dryer! Always better to warm it up a bit 'otherwise you risk that take away the paint below!
Removed the first piece, no damage to the paint! :D
Removing the second piece, painted screws and glued the adhesive after heating it! I put a pinch of attack where it didn't adhere! Usually it doesn't adhere on the tip that one removes first!
Here's the finished result! I hope you like it! If you have suggestions for improving the quality of workmanship didn't hesitate to tell me! I'm curious of your opinion! :)
For the moment it's all about! At the next UP! :D
Here is another UP!
As I said the hdd were 2! Here's the second, I hope you like it!
The process was much the same as the first HDD!
I removed the adhesive, screws etc. to paint! I gave HDD the red and then a masked only time the part that I wanted to keep the red! So I saved masking process that could ruin the paint once detached!
There it cames back from the cellar with a new look!
And finally here it is more beautiful than before, one hopes
Let me know if you like and which of the two HDD favorite! Personally I prefer the latter
I like the latter as well (but with the same comment about the sticker ;)).
I know! Thanks a lot! :D
New UP!
It 's time to see how it came the painting!
I really like it :D
Here I had to remove the dust filter and put it behind the red grid, otherwise you could not see much of a red! Then with the simple Vinavil glue I glued it all!
Here's the finished result! I know it's different from the render I did, in which I had removed the black grid above, but I have to say that so I like more :)
All for today people! At the next UP! :D
New UP!
I would say to start!
We see the bars as they came! :)
I must say I really like it! Color is what I wanted
Here I decided to paint the screws to give contrast to the black rubber pads!
Now to the castle of HDD!
Here I put the carbon film, not on top of everything, but doing "motif" decorating only a few parts! Hope you like it!
Soon with New UP!
New UP!
Let's take a new look inside the case! Or at least let's try
This is the before
This is after!
I must say that I struggled quite a bit to work without removing the rivets of the case! What a great labor, I tried to be as accurate as possible! What do you say?
Brutus Brutus Wc Setup Worklog Gallery & Build Logs 39
V Worklog lian PC-P80 Gallery & Build Logs 61
stravinski stravinski's worklog Gallery & Build Logs 8
MrGiorgio Gio's waterkoeling worklog Gallery & Build Logs 74
