[Project Log] "Parvum|Beast" - Semi Sponsored Build
BeckModZ
It's Build Time Again !!
Hi Guys,
since nov-december 2014, I have been working on a case design in collaboration with Parvum Systems..
Basic idea was to take the Parvum Systems S2.0 case, Re-Design it,
and build kind of a Monster Blue Energy tribute build :) ..
I call it "Parvum|Beast" ..
FINAL IMAGES ARE UP
!!!! - FINAL SHOTS - !!!!
HERE'S A TEASER FROM THE FINAL IMAGES
Here's Why i ended up building a monster energy drink Tribute machine.
Well the reason why the monster logo and name plate is used in this build is because the Monster Blue Energy Drink, and Monster Gaming Army is what inspired this build..
Actually came up with the idea when i was googling the black/blue parvum systems s2.0 case, and was drinking my Blue Monster energy drink.
And have been wanting to build in a Parvum case for quite some time.
So I thought to myself, wth, why not build a parvum case inspired by the monster energy drink, and make it look Beastie :) ..
I mean, people build tribute mods to all kinds of stuff, so why not build a monster tribute machine :)
So please dont judge me for building a Monster tribute Machine, Instead enjoy the level of detail and effort i put into this build :)
below is the link to the post with a few pics of the original S2.0 case,
And the 3d renderings of the final design we made :)
Big Thumbs Up to Justin and the rest of the crew at Parvum Systems for this,
such great work and such great details !
These guys can make ANYTHING in Acrylic ! <3
Everythig in this little beast is going to be watercooled with parts from EKWB.com, and Coolerkit.dk
And all the PSU sleeving is from MainframeCustom.com
Here's a little teaser of what's allready been done, and more to come :) Enjoy
Progress Links :
Parvum|Beast Renders
Parvum|Beast Case Parts
Parvum|Beast Assembling The Case
Parvum|Beast The Hardware
Parvum|Beast Part 1 of the Watercooling parts
Parvum|Beast Part 2 of the Watercooling parts
Parvum|Beast The Fittings
Parvum|Beast The Sleeving Has arrived
Parvum|Beast The Polishing Of EKWB Waterblocks
Parvum|Beast The Liquid & Light Test
Installing the waterblocks Part 1
Installing the waterblocks Part 2
Test Mounting of the Waterblocks, and modding the flipped GPU. Part 1
Test Mounting of the Waterblocks, and modding the flipped GPU. Part 2
Silverstone AP121 Fans Are Here!
Figuring out the Loop
Reservoir Vinyl Sleeve
Re-Sleeving the fans, and extra sleeving arrived
Some More Sleeving, 24pin, 2 x 8pin and more
Finished Filling The Loop!!!
Cable routing, res change and M logo on GPU
Done Routing cables, Trying out blue Mesh
Status Updates :
The beast is done... Final images are UP
Specs for the Parvum|Beast :
Mobo: Asus Maximus VI Gene z87
CPU: Intel Core i7-4790k
PSU: Corsair AX1200i
Memory: 32 GB of HyperX "Beast" 2133MHz (Obviously )
GPU: Asus GTX 690 4GB
SSD's: 120GB Samsung Evo 840, 2 x 250GB Samsung Evo 840
Extra's
Monitor: Asus Swift PG278Q 27" 2560x1440 144hz
Keyboard: Roccat ISKU FX
Mouse: Razer Deathadder Chroma
Headset: Logitech G430 7.1 Surround
Watercooling Parts :
Radiators: EK-CoolStream PE 360, and EK-CoolStream PE 120
Cpu Block: EK-Supremacy EVO - Nickel (Original CSQ)
Gpu Block: EK-FC690 GTX - Nickel (Original CSQ)
Mobo Block: EK-MOSFET ASUS M6G - Nickel (Original CSQ)
Memory Blocks: EK-RAM Monarch X4 - Nickel CSQ and 2 x EK-RAM Monarch Module - Black (2pcs)
Fittings: Some EK-HDC Fitting 12mm G1/4 - Nickel, EK-AF Angled 2×45° G1/4 Nickel, EK-AF Angled 45° G1/4 Nickel and some EK-AF Angled 90° G1/4 Nickel
Tubing: Some EK-HD Tube 10/12mm 500mm (2 pcs)
Pump: XSPC Laing DDC-1T Pro 3.1 (10W) and EK-DDC X-TOP CSQ - Plexi or a Xres Top depends on what looks best
Reservoir: EK-RES X3 250, or EK-RES X3 150 or EK-RES X3 110, depends on what looks best
PSU Sleeving :
Sleeving: LC TELEIOS 4MM SLEEVE and LC TELEIOS 8MM/SATA SLEEVE
Cable Combs: Alot of clear LC STEALTH CABLE COMBS
And off cause a connectors, terminals and LC CUSTOM 18AWG WIRE – BLACK​
And Alot of other cool stuff, Pics will follow :)
Hope you guys like the renders and the design Idea :)
Will be making step by step pics of polishing, sleeving and everything,
so that people can see how its all done, and maybe if they dont allready know it, they can learn it :)
This Build is made possible By:
Stay Awesome Bro's,
BeckModz - Liquid Designs
Bijlagen
    49,8 KB · Weergaven: 3
BeckModZ
Parvum|Beast Design Idea and Renders from Parvum Systems​
Here's the Original Parvum Systems S2.0 and the final render design layout that we agreed on.
Hope you like the design :)
The case has arrived, and i will post pics of the assembly very soon..​
BeckModZ
Parvum|Beast The Parts For The Case​
Here's all the case parts, pics of every single part by it self..
I am so amazed by the work Parvum Systems has done! Excellent work guys! <3​
BeckModZ
Part 3 of the watercooling parts - The Fittings
Here's all the fittings that i will be using in the machine,all from Coolerkit.dk and Ekwb.com
Next update will probably be either some light teste of the RGB Led's that will be mounted in the case, or some pics of Polishing the Waterblocks​
BeckModZ
The sleeving has arrived​
Here's the sleeving and some extra cool stuff from Mainframecustom.com <3<3
Absolutely in love with the blue colored sleeving, looks so sweet!. Cant wait untill i get to the sleeving part!​
BeckModZ
The Polished EKWB Waterblocks​
So i just finished polishing the "Frosting" of the waterblocks, and i must say it looks SOOOOOO much better this way :D
I was recording video when i polished the last block, but the camera fell on the floor :D ..
so no video at this time, but will make one later so you guys can see how its done :)
Cant wait to see how it looks with liquid in them.. ! Will take some pics later with the blocks filled up and under different light :)
tijgervarken
Tijgervarken knor roar
What you also can do, is put a small (read very tiny) peace of accrylic in the in- and outlets and put a bit of coolent in it. Then you (and we :p) will have an impresion of how it will look. BTW, looks nice already!
BeckModZ
Was thinking about taking the cpu block and fill it with the RED ekoolant,
and take the Monarch ram block and fill with the UV BLUE ekoolant,
and then have both of them under different lights, UV, and all shades of blue with the RGB Led :)
And then take some pics and upload here so people can give their openion on what looks best :)
ThomasJS Project SteelOak Gallery & Build Logs 0
Bl4ckj4ck666 Project Antec P120 crystal Gallery & Build Logs 21
Tath Project D Gallery & Build Logs 89
vincent Project Back in busines Gallery & Build Logs 42
2kPro [WorkLog] Project Scarlet|Ti Gallery & Build Logs 39
D Project Slick Gallery & Build Logs 23
