New water cooling build - need help
bugsynz
Hi all,
I am halfway through building my first custom water cooled pc and decided that I would rather pay someone else to do it as I’m not comfortable finishing it myself.
Are there people that offer this service around central Amsterdam? I cannot find anything when searching.
I apologise if this is in the wrong forum, just really needing to find someone to help :)
T water cooling pc maken Advies Waterkoeling Setup 1
ShadowBumble Water cooling setup Project Aqua Advies Waterkoeling Setup 7
P water cooling set Advies Waterkoeling Setup 12
Blackruby Beginners Guide To Water Cooling Handleidingen en Installatie Tips 9
W Corsair Cooling Hydro H30 water cooling block HighFlow Product Suggesties en Nieuws 20
S terug trekkend water?? Waterkoeling 11
