ModMyToys 3-Pin Power Distribution PCB 3xWay Block [MMT-PCB-3WAY]
Sw333t
I Love my NUC
Freddy,
Kan jij onderstaande leveren en zo ja, tegen welke prijs en levertermijn.
Naam product:
Productcode: MMT-PCB-3WAY
Naam fabrikant:
ModMyToys
Omschrijving product:
The 3-Pin Power Distribution PCB 3xWay Block is the perfect organizational solution for hard core modder's, water cooling enthusiasts and other power users that use a large amount of cooling fans in their systems or servers. Why use clumsy Y splitters that just add to cable clutter when you can have a clean point to distribute power to all your 3-pin fans? These small PCB's are made of the highest quality and include and easy to install preinstalled black mount rail and Velcro strip. This allows you to mount virtually anywhere in your case including all those hidden places modder's like to route their cables to. For those that want the best look these have a black PCB and connectors. So, eliminate all those extra cables and install the ModMyToys 3-pin power distribution PCB to be a Pro!
Input Power:3-Pin
Output Power:3 x 3-Pin
Note: Please make sure you do not exceed your 3-pin fan headers maximum wattage by overloading more high wattage fans then the motherboard or fan controller can handle. Please consult your products manual. You could though plug these into a 4-pin to 3-pin adapter and plug direct to your PSU which can handle many more fans at once.
Link/URL naar website van de fabrikant + pagina van het product:
Mod My Toys
Link/URL naar Reviews van het product:
Geen gevonden.
Adviesprijs en eventueel een link naar het productpagina bij andere shops:
3-Pin Power Distribution PCB 3xWay Block (MMT-PCB-3WAY) - FrozenCPU.com
Foto's van het product:
Overige informatie:
Zitten hier ook kabels bij voor connectie tussen pcb en moederbord?
Heb er 2 nodig.
[MENTION=1]Freddy[/MENTION]
Wellicht is het raadzaam om al die ModMyToys pcb's retour te sturen naar je leverancier in verband met een ontwerpfout van die printplaten.
Alle rpm sensors worden namelijk doorverbonden met elkaar, dit gebeurt normaliter bij geen enkele splitter en hier raakt een moederbord / fancontroller ook erg van slag.
Rond 1:28 :
Zo zit het nu (klikken voor grotere foto):
En zo zou het moeten zijn:
Dit is in ieder geval bij het product die ik heb zo, maar ik vermoedt dat het ook is bij de andere printplaten van ModMyToys:
ModMyToys 3-Pin Power Distribution PCB 5xWay Block - MMT-PCB-5WAY,
ModMyToys 4-Pin PWM Power Distribution PCB - 8x Way Block - MMT-PCB-4P-84P,
ModMyToys 4-Pin PWM Power Distribution PCB 4x Way Block - MMT-PCB-4P-44P,
ModMyToys SATA to 8x 4-Pin PWM Power Distribution PCB - MMT-PCB-LP8-PWM
De PWM versies ben ik niet helemaal zeker van, mocht je daar foto's van hebben (van de achterkant van de pcb) dan kan ik dat wel nachecken eventueel.
Lekker simpel antwoord. Kunnen ze dan ook verklaren waarom die rpm hem flipt bij het gebruik van 3 exact dezelfde fans (Noiseblocker XS-1).
Plus dat de rpm signaal nu na het aanpassen van de pcb's wel goed uitgelezen wordt?
Als je een gaatje of een snee kan maken tussen het 2de en derde contact zou het inderdaad moeten werken zonder problemen, het lijkt erop dat de RPM met deze setup bij elkaar word gegooid en dus verwarrende informatie terug stuurt.
Edit: Ik zelf gebruik daarom deze, waar een enkel kanaal RPM data terug stuurt en de andere gewoon hetzelfde voltage ontvangen.
Swiftech 8 way PWM Splitter 8 Watt
Swiftech 8 Way PWM Splitter - 8W-PWM-SPL
Dom antwoord van ze zeg, zo werkt RPM helemaal niet, is een puls signaal.
Dus al gebruik je 3 exact dezelfde fans zullen ze nog alle 3 een verschillend signaal afgeven ... en dus het main signaal totaal verneucken.
Hun antwoord gaat dan ook over de DC (3-pins) versies. De pwm versie weet ik niet van of ze goed zijn. Ik heb het vermoeden dat ze net zo doordacht zijn (not) als de 3-pins variant.
Ik vraag mij wel af hoe die PWM versies eruit zien aan de onderkant.
Bedoelde meer dat ik zeker weet dat het bij die 3-pins pcb's van hun dus fout zit. Bij de pwm versies weet ik dat niet. Als ze daar ook alle rpm pootjes aan elkaar hebben zitten, dan zal het ook hetzelfde probleem geven.
H ModMyToys 3-Pin Fan Splitters / Power Distribution PCB's HighFlow Product Suggesties en Nieuws 5
Besje ModMyToys Vandal resistant switch 22mm - momentary RGB HighFlow Product Suggesties en Nieuws 6
Jason DarkSide 5v 3-pin D-RGB 2-Way or 3-way splitter cables - Jet Black Sleeved HighFlow Product Suggesties en Nieuws 0
L USB 3.0 20 pin mainboard Splitter kabel? Hardware & Software 5
meneer peer 24 pin extenders >30cm HighFlow Product Suggesties en Nieuws 4
R 4 pin pwm splitter Overige Koeling 3
M Female To Female 4-Pin of 3-Pin Connector HighFlow Product Suggesties en Nieuws 6
X fan 3 pin of 4 pin voor radiatoren en fan control Waterkoeling 17
W pin / terminal voor CCFL connectors HighFlow Product Suggesties en Nieuws 0
NAVYVIPER Bitfenix 4-Pin 12V Verlengkabel - 45 cm HighFlow Product Suggesties en Nieuws 6
I psu 8 pin verlengen Cases en Modding 2
L 140 -> 120 fan welke rpm en verschil 3 pin en molex connectie? Overige Koeling 4
Luculenus 2-PIN 5MM LEDs HighFlow Product Suggesties en Nieuws 3
U 2 pin kabel met knop gezocht HighFlow Product Suggesties en Nieuws 1
P Scythe Shuriken Rev. B SCSK-1100 4-pin on old (supported) 3-pin Socket 478 mobo Overige Koeling 1
E 4-Pin Molex Female UV blue HighFlow Product Suggesties en Nieuws 1
Forseti AC to 12v DC Power Supply with 4 Pin Molex HighFlow Product Suggesties en Nieuws 3
dark viper zwolle 8 pin pci-e y splitter HighFlow Product Suggesties en Nieuws 7
Skydrone 2-pin LED strips HighFlow Product Suggesties en Nieuws 10
B [IN-ACTIVE] 4pin + 24 pin extensions Gevonden 0
R 3-pin fan kabel sleeven. Cases en Modding 10
Sw333t 4-Pin Molex Male Black ACR-CB8539 HighFlow Product Suggesties en Nieuws 9
M 3-pin Y splitter, 2x 12V HighFlow Product Suggesties en Nieuws 2
