Hoe snel kan jij typen? Post je score! :)
kan veel sneller.
weet dat ik eens 100+ gehaalt heb hier mee
You reached 0 points, so you achieved position 3888 of 3888 on the ranking list
You type 399 characters per minute
You have 0 correct words and
you have 128 wrong words
hij flipt m erna.
gewoon op toetsenbord tikken (willekeurige letters en spatie)
You reached 190 points, so you achieved position 1633 of 4064 on the ranking list
You type 233 characters per minute
You have 34 correct words and
you have 0 wrong words
<a href="http://dutch-speedtest.10-fast-fingers.com" style="display: block; width: 300px; height: 100px; background: url('http://speedtest.10-fast-fingers.com/img/badge1.png') no-repeat; padding-top: 50px; padding-left: 60px; color: #009933; font-weight: bold; text-decoration: none; font-family: Times New Roman, Arial, serif; font-size: 40px;">34 words</a><p><a href="http://dutch-speedtest.10-fast-fingers.com">Speed test</a></p>
hij flipt m erna.
You reached 0 points, so you achieved position 4074 of 4074 on the ranking list
You type 459 characters per minute
Faceroll??!?! WUAHAHAH :D
Ik zag het al voor me, maar heb voor de zekerheid even gegoogled:
Faceroll describes an individual who plays a class in a video game that is considered overpowered. The individual literally only has to roll their face over the keyboard repeatedly to win a match.
Facerolling is to roll one's face across a keyboard to win at everything. However proper facerolling technique is required to beat other facerollers. One must faceroll from left to right and throw in some elbow smashing just for good measure.
xD
<a href="http://dutch-speedtest.10-fast-fingers.com" style="display: block; width: 300px; height: 100px; background: url('http://speedtest.10-fast-fingers.com/img/badge1.png') no-repeat; padding-top: 50px; padding-left: 60px; color: #009933; font-weight: bold; text-decoration: none; font-family: Times New Roman, Arial, serif; font-size: 40px;">62 words</a><p><a href="http://dutch-speedtest.10-fast-fingers.com">Speed test</a></p>
toch een vijfde plaats :)
:edit
k zal het van de week nog even op mijn eigen toetsenbord proberen:024:
You reached 275 points, so you achieved position 1376 of 6464 on the ranking list
You type 360 characters per minute
You have 54 correct words and
<a href="http://dutch-speedtest.10-fast-fingers.com" style="display: block; width: 300px; height: 100px; background: url('http://speedtest.10-fast-fingers.com/img/badge1.png') no-repeat; padding-top: 50px; padding-left: 60px; color: #009933; font-weight: bold; text-decoration: none; font-family: Times New Roman, Arial, serif; font-size: 40px;">54 words</a><p><a href="http://dutch-speedtest.10-fast-fingers.com">Speedtest</a></p>
Eerste keer dat ik het deed, op een vreemd toetsenbord en niet echt oplettend. Thuis nog eens proberen :) . Was ff wennen ook hoe hij reageert :eek: .
Sw333t Het verbaasd me keer op keer hoe snel Highflow levert HighFlow Testimonials / Shopreviews 0
Celly Hoe snel beschadigt een GPU Overclocking 5
