Help - Bitspower Z-150 thread cracked - Seeking compatible alt.
memoryJam
Hi all,
Using the Bitspower Z-150 Reservoir with the Bitspower D5 Mod top - All acrylic. I've only had the system up and running for < 3 weeks and have noticed some hairline cracks around the threading on the reservoir that goes into the Mod Top.
Doesn't appear to be Bitspower branded replacements of the reservoir alone. I hacve to buy it with the bracket + Pom top which isn't required.
Does anyone know if the threading on these would be compatible? Koolance Reservoir Body 60x30mm (WxL), 59ml BDY-TK030
or perhaps any other reservoir that has the same diameter and threading as the Z-150?
If not i'll have to bite the bullet and buy a replacement bitspower Z-150.
Thanks all,
DannyKiers Help een newbie bekend worden met waterkoeling en modding Advies Waterkoeling Setup 14
