Rads and Fans
WE BACK WE BACK!
on time for once
a small update, but one of many...
ITS PEXON TIME WOO PEXON GO PEXON!!
So long story short, with such demand at work and focusing my time in much needed places (being slapped up if I stay at work too late).. I had to call in reinforcements. Doing this level of work was just not feasible. I suppose that's the great thing about having awesome friends. We've known James of Pexon PCs for some time now and each time we get around to hanging out its great fun. Roll on iSeries...
Moving onto his work of wonders; The job was to do exactly what I showed in one of the earlier posts. Different custom length wires then braided in
MDPCX Shade 19. A very fiddly solder job indeed. The points are pretty close together on
fans and this isn't helped when the wires are all black.
To make things even harder each fan had to run to a single 3pin header. Basically a daisy chain to allow us to run 16
fans from just 8 fan headers. The controllers being used here has more than enough power to do this:
Thank you very much mate and indeed I owe more than beer!
Next now that the
fans are ready it was time to start
fitting the radiators. See close ups of these beauties in one of my first posts. Using the
XSPC AX series:
Had to connect the two rads together as they will both be working in the same loop. First try was a male to male and a male to female extenders. Sadly too short by about 5mm. Sad Panda
Considered searching for a differnt length extender but the problem with this build is the black chrome finish. Parts are much fewer than standard chrome finish for example.
Decided to go with a baby piece of acrylic tube. I suppose the extra work was a bit annoying but got the job done:
Installed 4
fans and two rads and got connected up. Managed to squeeze all 4 cables between two
fans which was tight but neat!
Little test fit in the top of the case:
SADLY my friends... that is it. I started to fit the next two rads in the bottom of the case but ran into some design complications so have to figure a few things out before the next update.
My only other frustration here is the slight bow that's happening in the roof of the case due to the weight. This wont happen once the side panels are on as they will take all the weight but it's a bit annoying when building. May make a little reinforcement as the side panels wont be cut to the VERY end.
Thanks again for reading.
