[WorkLog] Project Scarlet|Ti
New up!
To enter the new mask for the three fans I had to cut away this part:
To cut it I removed the blade from the hacksaw and holding it in his hand, I cut.
This is because with the detached blade could easily reach the edge, but I will not recommend it highly.
This is the result! I know it's not much, but don't worry I'm working on the mod, or better a couple of things that I need for the mod!
For example the restructuring of the cellar, creating a painting booth home made, at least I have a place where I can work in peace!
Currently I have gone on to the pieces of CAD! As soon as I finish the ideas, I'll post something!
In the next days new up!
Here I am with a new up!
Today I painted the cover of the PSU!
font%3E%3Cspan%20style=font-family:%20arial%20narrow%3E
First a base coat, after cleaning the piece and sanded
Then down to paint!
Now the part is ready to be mounted!
Very satisfied with the painting
You like? How is now the case?
Now I go a week in Barcelona, when I get back important news! :icon_cool:
At the next UP!
NEW UP!
To make room for the radiator front that will insert with 6 fans in push / pull and not to stand too close to the PSU, I had to drill at a distance about halfway between the last and second last hole factory in this case!
Here are pictures :D
Holes made with a bit of trouble because I was quite uncomfortable for drilling :(
Well the carbon films make good :D
Here is the first hdd makes his entrance :p
Hope you like it! As always, comments and suggestions are always appreciated! :)
At the next UP! :D
Looks stunning, nice job.
New up!
UP
We begin !! ;)
sy5LVyd.jpg​
Photos because of the light and of my poor ability with the camera have given birth these colors :huh:
Live makes much better! :p
TVpxH8o.jpg​
This is the grid! I must say that I like very much because of the contrasting black and red! I thought worse! Then viewed from above can see very well the color red, as we tilts toward the edges less and less :) Same principle of TN panels ahahahah :D
Here's the last picture! Believe me that the colors are much more beautiful
Guys I hope that with this last one up wholly follow you Obviously guys aspect advice and your opinions! Even tips on how to improve the build and advice on how to make better pictures!
Thanks Corsair for the trust you have placed in my project and especially thank you JON, without him this wouldn't have been possible!
Exceptional products! Unquestionable quality. As you saw, I received power 1000W Platinum + Corsair Link + 2 RGB LED strips + Various cables.
I'm very happy because it's my first build and get the trust of a big company like Corsair, for me it means a lot!
Thanks to all of you to follow my project, because also without your support I wouldn't have succeeded! :D
Thanks CORSAIR!
Here I'm back with a BIG Up!
Has arrived almost any material of this sponsor, it's missing only the mouse that wasn't available. It will be provided later and will also be the subject of modding :D
But now we move on to serious matters!
Thanks CoolerMaster for the trust you have placed in my project and especially thank you ALESSANDRO E VINCENZO, without they this wouldn't have been possible!
Now the Pictures! :D
See you soon at the next up ;)
NEW UP
As I said I was in work in progress for the work in the cellar .. We almost finished restoring
I had some material in surplus, and so I decided to create a spray booth
I created using scrap pieces of wood, metal and plasterboard!
The orange parts are the simple tape to protect the wires!
Internally we have used glass wool to be glued to the plasterboard, to ensure that the dusts of the paint adhering to the surface and do not flutter on the piece.
The wall behind was made with plasterboard to cover the wall and keep it safe.
If you see before we tried with the spray glue, but it was drunk from plasterboard, then we switched to the option B
Good old silicone
To adhere the glass wool at the side of iron, we have drilled the metal pieces to pass the wires and hold the glass wool anchored on three points
With some mishap and various fix with what I had in the cellar
We have stretch a braided metal cable to carry the weight of the hanging pieces and so we set like this:
Internally set like this:
And here's the final result:
Aesthetically it's not much, but at a functional level is the best that I could create with what I had .. Cost = 0
I just have to buy two or three aluminum trays to be put on the table and fill them with water, to gather dust that falls while I paint and then periodically change the water and / or trays!
Keep in mind the negligible cost of the trays € 0.30 each one ..
I thought of a vacuum cleaner, but it cost me more and then I live in an apartment building .. I can not take a cab industry in the cellar, otherwise other people cause me problems ..
I Aspect your comments and opinions !!
That's all for now!
New UP!
Gentlemen, new arrivals in 2k Pro home! For the happiness of my wallet
These are sponsored by Me
Here is my latest purchase, I present my new modding partner
New Silhouette Cameo
A big man with a great message:
Comments and opinions are always welcome! Does anyone have experience with this machine?
Here is a video that shows the use of an expert !! JAMES WALTER
Thanks BitFenix for the trust you have placed in my project and especially thank you UMBERTO, without him this wouldn't have been possible!
Inside, many beautiful things :D
General Overview! But now we go into detail! :)
They look like general LED strips, but they aren't :) Since I'm an eternal undecided, I opted for the magnetic strips ;) So I can experiment to good light effect in my mod :D
Then I chose the Spectre LED PWM for the front of the mod! They will give that extra touch to the mod, without affecting the performance :)
And finally the Spectre Pro PWM :)
Gentlemen for this first overview is all! I, as always, invite you to leave a like on facebook, for those who had not yet done! For you are a few seconds for me it means further enhance my work :)
https://www.facebook.com/2kProModdingProject
Thanks to all! At the next UP! ;)
Brutus Brutus Wc Setup Worklog Gallery & Build Logs 39
V Worklog lian PC-P80 Gallery & Build Logs 61
stravinski stravinski's worklog Gallery & Build Logs 8
MrGiorgio Gio's waterkoeling worklog Gallery & Build Logs 74
