Vista x64 kan updates niet installeren
Hebben jullie weleens problemen gehad met het installeren van Windows Update?
Ik kan KB938194 niet installeren, mislukt telkens.
Het zelfde geldt voor Vista SP1, welke ik nodig heb voor GTAIV :sad:
Uiteraard al gegoogled en dit gevonden en zonder succes geprobeerd :(
Working with another MVP we have discovered that the update appears to
install properly and is repeatedly reoffered after installing it.
The issue is that one of the Packages containing a Component update, in
this case, WindowsCalendar, fails to install due to there being no
Windows Calendar folder being present in Scheduled Tasks.
The Windows Calendar folder had been deleted.
The result is the Package fails to install, thus the Components listed
on the KB page are rolled back.
The other Packages of the update do install, thus, the update is reoffered.
Workaround:
Open Task Scheduler, and in the Windows folder
add a WindowsCalendar folder.
No task has to be assigned, just create the WindowsCalendar folder.
Install KB938194 now.
Verder heb ik ook de update voor het fixen van Update systeem geïnstalleerd:
Downloadinformatie: KB947821: Hulpprogramma System Update Readiness voor Windows Vista voor x64-systemen [augustus 2008]
Proberen te installeren met alle programma's afgesloten, met name anti-virus programma (Kaspersky).
Iemand nog tips?
Legaal!
Ik heb ook al dit geprobeerd:
Click Start, and then type cmd in the Start Search box.
In the results area, right-click cmd.exe, and then click Run as administrator.
You will be prompted to type the password for an administrator account.
Click Continue if you are the administrator or type the administrator password.
Then, click Continue.
At the command prompt, type Sfc /scannow, and then press ENTER.
The scan may take some time, so be patient. Windows will repair any corrupted or missing files that it finds. If information from the installation CD is needed to repair the problem, you may be prompted to insert your Windows Vista CD.
Als ik dat doe zegt die dat er beschadigde/corrupte bestanden zijn gevonden, maar niet gerepareerd kon worden aarggghhh.
Tis ook altijd wat :p
Ik ga denk ik maar Vista weer eens opnieuw installeren, maar dan na installatie gelijk SP1 proberen te installeren.
Damnnn wat kost dit veel tijd!
Freddy, legaal. Dus je hebt een Key toch?
Download je nu al trouwens via nieuwsgroepen? Ik download altijd de laatste
Vista Ultimate 64-bit met de laatste updates geïntegreerd en OEM (geen activatie
etc.).
Deze link bevat de laatste updates t/m januari 2009.
Twee jaar geleden toen Vista net uit was legale DVD gekocht :)
Dus ja, met legale key.
Offline installeren ook geprobeerd, krijg dan foutmelding tijdens installatie.
Opnieuw opstarten is wel 1000x gebeurd.
Helpt niet :(
Het blijft vreemd Freddy, al die trucs die je heb moeten uithalen voor een
simpele SP1.
In de toekomst, download een bovenstaand pakket met alles in 1.
En het scheeldt je een hoop tijd, want al die updates bij elkaar is praktisch
ook weer een halve dag :)
lieve freddy,
ik heb het probleem ook.
Mijne is ook (i?)legale versie, wat ik toen gedaan heb is:
1: de update uitgevoerd
2:de code van de updats dat mislikt is gecopieerd
3:de update opzoeken bij windows zelf
3:de update installeren vanuit de website
3:98% gaat dan in een keer goed.
dat kost misschien meer werk, maar dan heb je gezeur over update niet meer.
mocht je windows 7 willen, ik heb de key ervan om zo te activeren
windows 7 is nog steeds in beta tot juli, dus activeren maakt niet zoveel uit. die code kan je online gratis aanvragen dusja.
Ik raad aan om NOOIT een OS via nieuwsgroepen of torrents te downloaden omdat je dan helemaal niet weet wat erin is gestopt etc. gewoon kale zooi halen van Technet of de andere OFFICIELE kanalen.
chicken PC sluit niet meer af na upgrade van Vista naar W7 Problemen & Oplossingen 2
Katsie Windows Vista gedeelde mappen verwijderd, maar nog steeds zichtbaar op netwerk?! Problemen & Oplossingen 6
jerome2710 vista boot niet, W7 wel... Problemen & Oplossingen 0
Don_Holio Windows Vista 64: "A pain in the *ss?" Hardware & Software 5
hung Autocad 2009 64bit op vista 64bit Hardware & Software 2
Foxdelta-Mods Hoe te switchen tussen Vista en Linux Hardware & Software 5
RRPhantom QX6850 & Asus Rampage Extreme wel POST, geen Vista boot Overclocking 9
basjuh Vista Setup Error Hardware & Software 3
P Bios ziet HD maar Windows Vista niet... Hardware & Software 16
R OS Vista 64 Bit Hardware & Software 16
N 4GB ram in vista 32-bit Hardware & Software 11
Yil Licence key Vista Buss. herbruiken. Hardware & Software 4
maomanna Full format tijdens installatie Vista Handleidingen en Installatie Tips 12
maomanna [Windows Vista] Vastlopers Hardware & Software 20
RusH xp 32 of vista 32 of vista 64 Hardware & Software 33
