EK-Loop Connect 51, Fan, Pump and Addressable D-RGB controller
EK heeft een controller ontwikkeld, waarmee je jouw ventilatoren, pomp én ARGB/DRGB led strips kan besturen!
Meer info: https://www.ekwb.com/custom-loop/connect/
Op het moment nog niet officieel leverbaar, dat zal waarschijnlijk in Januari zijn.
*update donderdag 20-02-20*
Verkrijgbaar bij HighFlow, in de shop:
Maar tijdens Black Friday mogen wij alvast enkele stuks weggeven :D
De voorwaarden zijn simpel, bestel vanaf morgen 250 euro aan EKWB producten en we doen er een EK-Loop bij.
Zolang de voorraad strekt!
Ze zijn nu beschikbaar en direct leverbaar uit voorraad!
The EK-Loop Connect is a powerful, straightforward information and control hub for all the relevant parameters in your liquid-cooled PC. A Fan, Pump, and an Addressable D-RGB controller unit that is designed from the standpoint of an enthusiast, but at the same time, not over-engineered. The easy-to-navigate software interface is simple enough for beginners and advanced enough for enthusiasts. The key features of the software are thoughtfully laid out to keep custom loop liquid cooling healthy!
The EK-Loop Connect is one of, if not the most powerful mainstream fan and LED controller available on the market, topping off at 170W of total power delivery. It's capable of delivering 20W per each 4-pin fan header, combining up to a total of 120W. The industry-standard, non-proprietary addressable D-RGB headers can each handle 8W of power.
EK Loop Connect D-RGB and Fan controller
With six PWM fan headers capable of delivering a total of 120W (20W per header), you can connect multiple fans since standard PWM splitter cables can also be utilized. The same applies to the addressable D-RGB headers as they can deliver up to 8W of power on each connector. Each header can be used to connect multiple D-RGB products by using an EK D-RGB splitter cable. To put it into perspective, that's enough for ~20 EK-Quantum Vector D-RGB water blocks. For specific EK-Quantum D-RGB water block power consumption check the table on our blog.
The unit is equipped with several safety features that ensure a restless a worry-free experience with the EK-Loop Connect. The built-in temperature sensor will make sure the fans and attached pumps are ramped up to the maximum speed if the software records CPU temperatures over 90-100°C.
EK-Loop Connect
An LED overpower protection system will make sure you will not damage the controller unit or your addressable D-RGB LEDs. If by any chance, one of the D-RGB headers will be overloaded, the unit will automatically set the color all the LEDs attached to a red color. A static red color is using only 1/3 of the total power draw and also acts as a warning color for the user to take action and reduce the number of LEDs attached.
Technical Specifications:
- Dimensions (L x W x H): 126x70x18mm
- Power Output for Fans: 20W per header
- Power Output for LEDs: 9W per header
- Mounting Holes: 2.5" drive mounting holes
Ports:
- 1x (PWR) 4-Pin Female Molex (2x Female SATA to 1x Male Molex Adapter Included)
- 6x (F1-F6) Standard 4-pin PWM Fan Header
- 6x (L1-L6) D-RGB Header 3-Pin 5V Digital LED Header (Pinout: +5V, D, Blocked, Ground)
- 3x (T1-T3) Temperature Probe Headers
- 1x (FLO) Flow Meter Connection (upcoming product)
- 1x (LVL) Coolant Level Indicator (upcoming product)
- 1x USB 2.0 Data Header
- 1x (EXT) Data Header 4-Pin 2.5mm Pitch for Daisy Chain (upcoming product)
Designed and engineered by EK Water Blocks in Slovenia - Europe
Made in China
In de shop:
Jason EK-Loop Connect Level Sensor TBE 60 HighFlow Product Suggesties en Nieuws 0
P EK Loop connect Waterkoeling 3
R Complete dual loop te koop [Hardline] Hoop onderdelen Te Koop 6
Jason EK-Loop Heat Gun 2000W HighFlow Product Suggesties en Nieuws 0
Jason EK-Loop Leak Tester Flex HighFlow Product Suggesties en Nieuws 0
Jason EK-Loop Torque Schroevendraaier - 0.6Nm HighFlow Product Suggesties en Nieuws 0
P Dubbel Loop Systeem voorbereiden. Shopping List Advies Waterkoeling Setup 2
C schuim in loop Waterkoeling 10
Jason EK-Loop CMS HighFlow Product Suggesties en Nieuws 0
O Aanpassen bestaande loop Advies Waterkoeling Setup 3
M Triple loop extreme overkill Gallery & Build Logs 9
brepoels peter Tweede loop maken. Gallery & Build Logs 8
F Double AIO of Full loop? Advies Waterkoeling Setup 9
Freddy EK-Loop Modulus Hard Tube Bending Tool HighFlow Product Suggesties en Nieuws 0
Slader Full hardline loop Waterkoeling 2
