H hans_broers Member 26 februari 2013 #41 Update, missing 2 fittings so had to improvise also mounted the CPU block
N noob2070 Young, Wild and Free 26 februari 2013 #42 Nice, i tought you had the radiator now on the inside?
H hans_broers Member 26 februari 2013 #43 Tried but then i didnt have a safe place to put the pump, so i put it back on the outside
H hans_broers Member 26 februari 2013 #47 lol i have no way of mounting it in there, or atleast now in a way i now
N noob2070 Young, Wild and Free 26 februari 2013 #48 I tought you had a pic of the rad on the inside? Or wasn't it mounted?
H hans_broers Member 26 februari 2013 #49 Nop it wasnt, i was just trying but i had no place to screw it to :S
Das Experiment HR afdeling Forumleiding 26 februari 2013 #50 I see 2 places where you can put the rad.
Sw333t I Love my NUC 26 februari 2013 #52 Stil don't know why the rad won't fit in the front, like this: http://builds.vanwilligenburg.eu/main/CIMG5366.JPG I know, it's not the same rad as you got, but it still fits. Otherwise, get rid of all those nasty hdd bays.
Sw333t I Love my NUC 26 februari 2013 #54 Rotate the radiator 45 degrees, so the fittings are at the mobotray side or at side panel side. I'm pretty sure that it will fit.
H hans_broers Member 26 februari 2013 #55 wwwicked zei: Rotate the radiator 45 degrees, so the fittings are at the mobotray side or at side panel side. I'm pretty sure that it will fit. Klik om te vergroten...
H hans_broers Member 26 februari 2013 #58 Really i have no fucking luck at all!!!, made 2 fucking holes on the fucking RAD! SHIT!!!
