Silencio 550 watercooled
Case: Cooler Master Haf X Amd Edition
Mobo: asrock 970 extreme3
CPU: amd fx8120
CPU cooler: Custome Spin Q
Memory: 16Gb Corsair
Video card: Asus 6950 2GB
Psu: Cooler master silent pro m2 1000W
Hi Hans,
I got 2 6870's in my system. Does your's also have trouble with cooling? I have to manually set the fanspeed to 30 to 35% alse he get's 98 degrees..... In croffire and while playing a game offcourse.... I didn't even overclock them...
I know, bought this system from my brother. He had the same issues... With manual adjustment of the fan speeds there aren't any problems. But when i choose for the system to control it it really is getting way to hot. So i am manually switching the fan speeds. When I set them to 35% they are only 70 Celsius.... so that's acceptable. :D
Well, the airflow in the case isn't the problem, so yes, i have good flow. But the airflow to the second card is a problem. Becouse it's 2 slots high and the first coveres the second..... But still, when i manually control it and set it to 35% it's cooling good. Maybe the fancontroller onboard is just broken. I really don't know...
Hey CrizCroz, that's my case, sorry for the messup here. I take it out of this thread and post it at mine.
Edit: Nice Res btw. :D Is the pink from your water or is it the cleaningcloth youre using? ;)
Sw333t [VERKOCHT] Cooler Master Silencio 550 Verkocht 8
alain-s [VERKOCHT] Cooler Master Silencio 550 Limited Edition Verkocht 2
kier [CiP] Silencio 550 MbK Gallery & Build Logs 24
Traxtorm CM Silencio 550 HighFlow Product Suggesties en Nieuws 4
Sw333t [GEVONDEN] Cooler Master Silencio 550 behuizing Gevonden 1
I Cooler Master Silencio FP 120 PWM HighFlow Product Suggesties en Nieuws 1
Sw333t [VERKOCHT] Cooler Master Silencio 352 inclusief Seidon 240M Verkocht 7
gerjanlubbers CM Silencio Clean Mod Gallery & Build Logs 6
alain-s [CIP] CM Silencio Limited Edition Gallery & Build Logs 56
Sw333t [VERKOCHT] EVGA GeForce GTX 550 Ti FPB Verkocht 2
M Waterblock voor GTX 550 NVIDIA 7
Sw333t [GEVONDEN] A-merk voeding 450 - 550 Watt (stil) Gevonden 1
E Corsair VX-550 HighFlow Product Reviews 0
LoyalFoxx Evolv X Watercooled {COMPLETED} Gallery & Build Logs 20
C 1933 Philips 636A nagebouwd - watercooled PC Gallery & Build Logs 19
Enola strix 980ti watercooled temps Waterkoeling 7
T Watercooled GamePC Waterkoeling 4
N First watercooled setup Advies Waterkoeling Setup 5
G [CLOSED] Quad core game pc watercooled Gesloten 2
S Temperatuur Radeon HD 7970 Watercooled Waterkoeling 4
H [CLOSED] Watercooled Systeem Gesloten 1
Tokke Corsair Graphite 600T Watercooled? advies graag Advies Waterkoeling Setup 12
J Lian Li V2100 - Watercooled Gallery & Build Logs 22
Luculenus HD 6990 vs HD 7970 watercooled AMD / ATI 14
sir serial [VERKOCHT] Club3D 6990 (watercooled) Verkocht 6
l3p Watercooled Asus MARS II. Advies Waterkoeling Setup 39
S First watercooled PC 800D Gallery & Build Logs 3
H M'n Haf922 watercooled. Gallery & Build Logs 9
Baloo.be Powercolor HD5870 LCS (watercooled) HighFlow Product Suggesties en Nieuws 1
W Watercooled-ITX Gallery & Build Logs 13
Colossus PowerColor HD5970 Watercooled Hardware & Software 1
P nieuwe watercooled case gekocht en ik heb een vraag Advies Waterkoeling Setup 29
koendb Cosmos S watercooled! Gallery & Build Logs 34
V vhrgamer's watercooled Cosmos S build. Gallery & Build Logs 250
G Core i7 watercooled Waterkoeling 28
Joren Watercooled Devil- Rebuild Gallery & Build Logs 69
A Striker II formula watercooled. Gallery & Build Logs 7
Sp33dFr34k Cosmos S Watercooled Gallery & Build Logs 12
Xelation GTX280 EK Watercooled Hardware & Software 30
