Silencio 550 watercooled
I have had some problems with my ASUS 6870's. My problem wat the cooling didn't start soon enough. Had exact same problems like you describe.
Use the Radeon tools to set the fan speed higher (50% or so) and check your temperatures on a second display. I guess there is your problem.
The problem i had in detail:
The driver was set to a manual fan speed.
When i starten BF3 the fans tried to spin up but didnt (becouse they where set to manual).
I did a clean install of the drivers but still the same problem.
Then i found out about the fan settings. Now i set them to manual when i start playing a game.
Result, no more problems.
Highest temperatures i got with 1 of my cards was 103 degrees Celsius...... :S
Good luck and let me know what your card does with the manual fan speed settings and his temps. :D
By Radeon tools you mean "AMD VISION Engine Control Center"?
when i look at the fan settings it always says its on 10% and when i cranked it up sometimes it didn't do anything, i installed "MSI Afterburner" but later uninstalled it because i couldn't control the fans from "AMD ECC", and i have notice that the heat went up after i started the game, what it was doing before i removed it from my system was, when ever i started a game it kicked me out of the game and back to the desktop, so it wasnt showing me the striped screen..
Sw333t [VERKOCHT] Cooler Master Silencio 550 Verkocht 8
alain-s [VERKOCHT] Cooler Master Silencio 550 Limited Edition Verkocht 2
kier [CiP] Silencio 550 MbK Gallery & Build Logs 24
Traxtorm CM Silencio 550 HighFlow Product Suggesties en Nieuws 4
Sw333t [GEVONDEN] Cooler Master Silencio 550 behuizing Gevonden 1
I Cooler Master Silencio FP 120 PWM HighFlow Product Suggesties en Nieuws 1
Sw333t [VERKOCHT] Cooler Master Silencio 352 inclusief Seidon 240M Verkocht 7
gerjanlubbers CM Silencio Clean Mod Gallery & Build Logs 6
alain-s [CIP] CM Silencio Limited Edition Gallery & Build Logs 56
Sw333t [VERKOCHT] EVGA GeForce GTX 550 Ti FPB Verkocht 2
M Waterblock voor GTX 550 NVIDIA 7
Sw333t [GEVONDEN] A-merk voeding 450 - 550 Watt (stil) Gevonden 1
E Corsair VX-550 HighFlow Product Reviews 0
LoyalFoxx Evolv X Watercooled {COMPLETED} Gallery & Build Logs 20
C 1933 Philips 636A nagebouwd - watercooled PC Gallery & Build Logs 19
Enola strix 980ti watercooled temps Waterkoeling 7
T Watercooled GamePC Waterkoeling 4
N First watercooled setup Advies Waterkoeling Setup 5
G [CLOSED] Quad core game pc watercooled Gesloten 2
S Temperatuur Radeon HD 7970 Watercooled Waterkoeling 4
H [CLOSED] Watercooled Systeem Gesloten 1
Tokke Corsair Graphite 600T Watercooled? advies graag Advies Waterkoeling Setup 12
J Lian Li V2100 - Watercooled Gallery & Build Logs 22
Luculenus HD 6990 vs HD 7970 watercooled AMD / ATI 14
sir serial [VERKOCHT] Club3D 6990 (watercooled) Verkocht 6
l3p Watercooled Asus MARS II. Advies Waterkoeling Setup 39
S First watercooled PC 800D Gallery & Build Logs 3
H M'n Haf922 watercooled. Gallery & Build Logs 9
Baloo.be Powercolor HD5870 LCS (watercooled) HighFlow Product Suggesties en Nieuws 1
W Watercooled-ITX Gallery & Build Logs 13
Colossus PowerColor HD5970 Watercooled Hardware & Software 1
P nieuwe watercooled case gekocht en ik heb een vraag Advies Waterkoeling Setup 29
koendb Cosmos S watercooled! Gallery & Build Logs 34
V vhrgamer's watercooled Cosmos S build. Gallery & Build Logs 250
G Core i7 watercooled Waterkoeling 28
Joren Watercooled Devil- Rebuild Gallery & Build Logs 69
A Striker II formula watercooled. Gallery & Build Logs 7
Sp33dFr34k Cosmos S Watercooled Gallery & Build Logs 12
Xelation GTX280 EK Watercooled Hardware & Software 30
