Weetje van de dag
Left: All the water in the world (1.4087 billion cubic kilometres of it) including sea water, ice, lakes, rivers, ground water, clouds, etc.
Right: All the air in the atmosphere (5140 trillion tonnes of it) gathered into a ball at sea-level density.
Shown on the same scale as the Earth.
