TJ07 Inverted ATX
Alle losse onderdelen van de TJ07 zijn te koop :)
Kijk Flipmode, zo krijg je het wel voor mekaar :icon_pidu:
Betreff: TJ07BW Parts
Dear Silverstone representative,
I recently bought the TJ07BW case from my local retailer [highflow.nl], but I ran into 2 issues with it:
The case I recieved had the Xeon motherboard tray, wich has the giant gaping hole in it,
unlike what the photo`s on their website and yours show with a closed motherboard tray.
My question is this, is it possible to buy only the motherboard tray from Silverstone without the Xeon
support hole as shown in the pictures on the website?
SilverStone Technology Co., Ltd - Designing Inspiration
Secondly i wanted to ask if it is possible to buy a new side panel without the window?
Flipping the motherboard tray gave so much extra usable space, but left me scratching my brains where to find a closed panel :)
I have searched the web for these stand alone parts, but impossible to find them anywhere, hence this email.
The case is brilliant, exceeded my expectations from what I saw in 3 days comparing 100 cases, not a signle doubt has come across my mind since it arrived last week!
Best regards,
Als je ze maar netjes benaderd met een beetje slijmen ;)
thank you for your Email.
Attached you'll find an offer about
- Motherboard tray without hole
- Sidepanel black without window.
The motherboard tray will be available within 2-3 months.
Because of many requests, we started a new production of the old version.
The sidepanel will be able to deliver at the end of january.
We need your delivery and invoice address to complete the inquiry.
Payment terms:
- payment should be done in advance.
Best Regards
en gelijk besteld :p
lol ja, ik had toch echt verwacht dat ik tot volgende salaris zou moeten wachten omdat het iets van 120-140 euro zou worden (losse dingen altijd schijt duur), maar dit had ik dus niet verwacht :p
btw, dit is inclusief verzend kosten :D
Net die inverted back paneel bij chilledpc besteld met top window en wat andere .... , verwacht het hopelijk voor einde van de week als ze alles nog in voorraad hebben
zal wel laten weten of het echt bagger kwaliteit is of dat een dremel met een verf laagje genoeg is :)
ff een kleine update :)
vanmorgen het pakketje van chilled pc gekregen en gekeken naar de kwaliteit van de back panel
de kwaliteit is super
alles heel netjes gesneden
geen rafelingen
geen beschadegingen
net zo stevig als het origineel met zelfde dikte
zelfde afwerking, binnen spiegel glad en buiten ligte "brush"
of alle gaten perfect zitten zal ik van het weekend achter komen :p
morgen pakketje van freddy, zal dan proberen wat foto`s te maken, ook van het getinte top en zij paneel plexi voor je flipmode ;)
Offtopic: ik heb ook daar ook wat TJ07 parts besteld. maar hoe lang duurt het voordat de betaling overgeboekt is.
Bij mij staat hij nog steeds op goedkeuren voor buitenlandse transactie?
geen rafelingen
geen beschadegingen
G [CLOSED] Silverstone Tj07 alu brushed Gesloten 2
G Gio's TJ07 Gallery & Build Logs 15
JeanPaul [VERKOCHT] [ Rex3 , I7 980 , 12GB Dominators GT, SilverStone TJ07-BW] Verkocht 12
JeanPaul Jean - Pauls TJ07 V2 Gallery & Build Logs 9
alain-s [IN-ACTIVE] Custom made parts for silverstone TJ07 Verkocht 1
JeanPaul Jean Paul's SilverStone TJ07 Gallery & Build Logs 65
E EscapeX's TJ07 - Try-Outs! Gallery & Build Logs 17
E EscapeX - Ralf - TJ07 Introductie: Stel jezelf en jouw PC voor 8
Lqd [IN-ACTIVE] Silverstone TJ07 + Mods Verkocht 7
jerome2710 Jerome's TJ07 - MurderMod TJ07 Gallery & Build Logs 101
alain-s [IN-ACTIVE] Originele midplate van Silverstone TJ07 Gevonden 0
alain-s [IN-ACTIVE] Front en Midplate TJ07 Project Umbrella Verkocht 1
Lqd LQD - Custom TJ07. Gallery & Build Logs 12
Impulse TJ07 stuff HighFlow Product Suggesties en Nieuws 0
S Tj07 window vragen Cases en Modding 8
M Silverstone TJ07 * VOLLEDIG* zwart met window? Cases en Modding 1
Flipmode Blck TJ07 Verkocht 4
k.3nny k.3nny CleaN-TJ07 *build for WWW.HARD.FM Gallery & Build Logs 32
Flipmode Blck TJ07 + Super WC Verkocht 4
B Window TJ07 Cases en Modding 5
jerome2710 Silverstone TJ07 vraagjes Cases en Modding 12
G [CIP] Black Mythical TJ07 Gallery & Build Logs 62
R Acid Green TJ07 Gallery & Build Logs 53
pulse Mijn TJ07 Gallery & Build Logs 7
Traxtorm Lamagra TJ07 Gallery & Build Logs 162
V TJ07 Highflow Edition Gallery & Build Logs 206
Flipmode Blck TJ07 Gallery & Build Logs 121
M TJ07 "Maximus KaoS" Gallery & Build Logs 25
F Vraagje ivm TJ07 Handleidingen en Installatie Tips 4
thiesggb [VERKOCHT] Lian-li v-1000 zwart (inverted-atx, window-panel is optie) Verkocht 8
Mannozels MDPC-X Crimp terminals voor ATX 15-16AWG HighFlow Product Suggesties en Nieuws 2
M Micro-ATX in Mini-ITX behuizing? Cases en Modding 2
