Swiftech KOMODO GTX 980 waterblocks
SoleX
Beste Highflow,
Ik heb een bestelling bij jullie staan voor een Swiftech H240-x waar ik met smart op wacht.
Deze zou ik graag willen uitbreidden met Swiftech komodo gtx980 waterblokken, maar dat zijn nou net de waterblokken die ik niet kan vinden op uw prachtige webshop.
Is het wel mogelijk om deze via u te bestellen?
Alvast hartelijk dank voor uw antwoord!
- SoleX
coolfris
mooi blokje ;)
Swiftech KOMODO-NV-GTX9 for GeForce GTX 980 series - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit
Product Description
The Komodo™NV- GTX9 is part of the LE (Luxury Edition) family of full cover waterblocks, and is compatible with Nvidia® GeForce™ GTX 980 reference boards. The coolant flow path includes all critical components such as GPU, memory, power mosfets as well as all other power components specified in NVidia's "Thermal Solutions Design Guide".
Proper cooling of all the critical components contributes to overclocking stability, reliable operations, and longevity of the graphics card. The block covers the entire PCB, leaving no components exposed to possible damages during handling.
The product includes interchangeable color strips to light up the coolant window and front logo plate in 4 colors: Green (as shipped), red, blue or clear. The Komodo NV-GTX9 can be compared to the award winning Komodo NV-LE reviewed below.
What is included in the box
Water-block
Color Strips
Installation screws
Pre-installed thermal pads
A back-plate is NOT included (re-use the original graphics card back-plate)
Tim Mate 2 Thermal grease
(2) G1/4 plugs
Installation guide
Technical Specifications
Inlet & Outlet port thread standard:: 1/4" BSPP (G1/4)
Quality assurance: leak tested at 30 PSI
Thermal joints installation:
•GPU: thermal compound (included)
•Memory & power fets: pre-installed 0.5mm thermal pads
•Other components: high performance reusable 1mm gap filler
Housing material: acrylic
Base Plate material: Chrome plated C110 copper
Cover-plate material: Black anodized brushed aluminum
Dimensions: (L) 10.5" - 268mm x (W) 4.8" - 122mm x (H) .74" - 19mm (measured from GPU pedestal to top of housing)
Mass: 44 oz - 1247 g
videoreview:
review: Swiftech Komodo NV-LE GPU Block Review
psyduck170 [VERKOCHT] Swiftech Komodo 7970 Verkocht 3
R swiftech komodo connector HighFlow Product Suggesties en Nieuws 3
S Swiftech MCP655 pomp kapot? Waterkoeling 15
R Swiftech H220 HighFlow Product Suggesties en Nieuws 27
