Swiftech H220
PRE ORDER BIJ HIGHFLOW
http://www.highflow.nl/watercooling-sets/cpu-sets/swiftech-h220-all-in-one-cpu-cooler.html
Press Release
Swiftech® to unveil new H220 all-in-one CPU cooler during CES 2013
In a related announcement, the company disclosed that they had successfully developed and begun high-volume manufacturing of a new generation of Swiftech-made mini-pumps, specifically designed for the liquid cooling market. The pump combines a compact design, high-reliability (60,000 hours MTBF) and the high head-pressure performance characteristics necessary to drive multiple devices in the same cooling loop. Being PWM controlled, the device can be driven by any motherboard like a regular CPU fan. Thanks to this new pump and to substantial economies of scale, the company claims that their new H220 CPU cooler will offer thermal performance with a low to inaudible acoustic signature rivaling that of the best custom kits, all at the price of an entry level product. In the words of Gabe Rouchon, the company's Chairman and CTA, "This thing is ridiculously quiet; if the chassis light wasn't on, I couldn't even tell the system was running."
"with a 15 year heritage serving the enthusiast community, we also wanted to eliminate some of the limitations of the existing low-cost systems which are unable to accommodate add-on components because (a) they are sealed-up and offer no means to refill the system without voiding the warranty, and (b) the type of pump they use is not adequate to drive sufficient flow to cool more than a CPU. The Swiftech® H220 kit addresses both issues by featuring a reservoir with fill-port built into the radiator so that the system can be easily emptied or refilled by the user at will, and by our new high-pressure pump."
The H220 CPU liquid cooling kit is maintenance free for the duration of its 3 year warranty period, and will be offered at a Manufacturer Suggested Retail Price of $139.95
Hieruit blijkt dus dat het een echte H100(i) killer is. Kan jij het daadwerkelijk voor deze prijs leveren en wanneer verwacht je deze te kunnen leveren?
Gr. Reinoud
k.3nny
Oldscool.
Wolf in schaaps kleren, Vooral die laatste rig maakt het af :)
6 watt pomp, 3 redelijk dikke rads 2 gpu's en dan nog ziekelijk lage temps voor load, en aangezien het in vegas is is het buiten zo een 32+ graden, binnen 18-22 vind ik dat toch netjes ;)
Vind temps inderdaad goed voor een dun 240 rad. Daarnaast vind ik t zelf ook mooi om te zien dat je deze ook nog eventueel kunt uitbreiden naar je gpu's en dat is voor mij ook een groot voordeel aangezien ik atm geen honderden euro's kan uitgeven aan watercooling.
Rinneh
Dit setje wil ik maar al te graag aanschaffen. Alleen geen idee hoe ik dit in een SIlverstone Fortress 3 ga bouwen. Ik denk dat ik hiermee in combi met een leuk Geforce 670gtx blok in 1 keer dan klaar kan zijn.
WiSK
Wat een inmens verschil tussen de stock fans van de 220 en de Noctua's die hij gebruikt, djees!
Die Noctua's zijn misschien goed maar ik geloof nooit dat die kunnen zorgen voor een 20C verschil. De ontwerp van de Helix fans is gebaseerd op GentleTyphoons en ze hebben elders goede reviews. Wat betreft geluid ook vergelijkbaar met GTs.
Grappig ook dat hij verrast was dat pomp snelheid niet veel scheelde kwa temps.
S Swiftech MCP655 pomp kapot? Waterkoeling 15
ChillPascal Swiftech MCP35X2 Housing White HighFlow Product Suggesties en Nieuws 5
psyduck170 [VERKOCHT] Swiftech Komodo 7970 Verkocht 3
