Slechte support swiftech!!!
D
Deleted member 42
Guest
Hi There:
Unqualified noise and foam do not qualify for RMA.
The 355 in particular is a noisy pump to begin with, and while the 350 is a little quieter, it still cannot be called a silent pump. As to foam in your loop, this has nothing to do with the pump. You either had air in your lines, or a chemical contaminant that foamed up.
Best regards,
Gabe,
Dat ding maakt wel +40Dba!!!!:013::013::013:
ik probeer nu bij michelle van swiftech, zij is ook een van de bazen en is meer bezig met support en RMA ;)
Hopelijk krijg ik nieuwe hoor want het geluid is echt onhoorbaar...
Michelle :
I’m a little confused with your request. Before anything else, please note that our warranty for pumps is 2 years and we only send replacements (no return or upgrades) to customer in the US. If you’re in Canada or somewhere overseas, please send your RMA request to your local reseller.
If you want to troubleshoot your pump issues, you may call us at the Swiftech number below or email help@swiftech.com
Regards,
Michelle
Swiftech
151 West Victoria St.
Long Beach, CA 90805
Phone 310-7630336
Fax 310-763-7095
gabe :
Can you qualify the noise? if the bearings are out of order, then this qualifies for RMA providing that they are not older than 2 years.
Best regards,
Gabe
CONFIDENTIALITY NOTICE: The information contained in this email message and any attachments may be confidential and privileged, and exempt from disclosure under applicable law. This email message is intended only for the exclusive use of the entity or person to whom it is addressed. If you are not the intended recipient (or someone responsible for delivering this email message to the intended recipient), please be aware that any use, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify the sender immediately by return email or by telephone and delete or destroy this email message and any attachments to it. Thank you.
From: ward coysman [mailto:wardcoysman@hotmail.com]
Sent: Wednesday, December 02, 2009 12:33 AM
To: Gabe Rouchon
Subject: RE: RMA MCP355 and MCP350
I guess i will have to say swiftech goodbye and look for other products. And i wanted to ask you for cooperation in my future builds. Sorry gabe but i will not use products that make more noise then a fan @ 35-40Dba. I really like the MCP355 and MCP350 because i have them both at the moment running and almost no noise. I put my other 2 on and they are making noise like hell. You can hear that somthing is wrong.
U Goede en/of Slechte ervaringen met DPD? HighFlow Testimonials / Shopreviews 15
A XFX FX-797G-TDFC 7970 slechte reviews. AMD / ATI 4
G Goede ervaring Highflow slechte ervaring bezorgen HighFlow Testimonials / Shopreviews 12
P Slechte vertalingen/Geen Vertalingen HighFlow Webshop 5
JeanPaul Slechte flow ? Waterkoeling 3
Celly Help met slechte airflow Overige Koeling 12
F Slechte ervaring Highflow HighFlow Testimonials / Shopreviews 26
T Slechte koeling? Overige Koeling 5
Jason Brook Powerbay Portable and Fast Charging Stand, Docking for Switch, Compatible with Switch and GC Controllers, Support HDMI Output HighFlow Product Suggesties en Nieuws 4
Freddy HighFlow VH1 Adjustable Aluminum GPU/VGA Support Strut/Holder Anti-Sag HighFlow Product Suggesties en Nieuws 0
M Phanteks Enthoo Primo (Full tower, standaard 2 x 480 Support...) :) HighFlow Product Suggesties en Nieuws 27
J Windows support 1TB harddisk als C schijf? Hardware & Software 4
Fuwa Fuwa Input not support Hardware & Software 5
D X58 moederbord met ATI CF support? Hardware & Software 11
damunk Creative Support Lolz... Hardware & Software 5
