Metalcored00d - Custom bureau met waterkoeling
Metalcored00d
Jouw PC:
MOBO: Asrock Fatal1ty Z77 Professional-m
CPU: Intel Core i7-3770K
MEM: 4x Corsair Vengeance 4GB 2400MHz
VGA: 2x Asus Radeon HD7850 DC2T 2GDDR5
HDD1: Samsung EVO 840 256GB SSD
HDD2: Seagate 3TB
PSU: Corsair CX750M
CASE: custom desk
OS: OS X 10.10.5 / Windows 10 pro
MON: 2x HP V241a
KB: Ducky Shine III red
MOUSE: Steelseries Rival
MOUSEPAD: Steelseries
HS: Steelseries
SPRS: (speakers / luidsprekers)
INET: Voo; Downspeed: 75Mbps - Upload: 5Mbps
Koeling: Custom watercool loop
Alphacool NexXxos XT45 Full Copper 360mm radiator met push/pull config van 9 Aerocool Shark Devil Red 120mm fans.
CPU block is de Phobya UC-1 Extreme.
Tubing is simpele masterkleer :).
Ik heb 2x Phobya Balancer 250 reservoirs.
De pomp is een Laing DDC 12V.
P Gratis af te halen / over te nemen; custom sleeving Cases en Modding 1
ABRAWARE Starwars themed custom loop dreambuild Gallery & Build Logs 9
bunbun rx vega 64 gpu only custom loop Advies Waterkoeling Setup 2
B Corsair 250D tricky custom loop versch. vraagjes Advies Waterkoeling Setup 2
