Watercooling setup
revog
Hey Everyone!
This will be my first time doing something with watercooling,
So i was wondering what i needed i read a few forums and this is what i made.
Can someone tell me how far i get with a setup like this and if something's missing..?
(I'm sorry that i have to put my configuration like this, the PDF wouldn't download -.-)
MagiCool SLIM DUAL 240 Radiator
CODE: LC-RADI240 - SKU: LC-RADI240
Yate Loon 120MM D12SL-12 Clear + Red LED 1350RPM
CODE: D12SL12RLED - SKU: D12SL12RLED
EK-Supreme LTX AMD CSQ - Copper Acetal
CODE: 990761 - SKU: 3830046990761 - EAN: 3830046990761
Alphacool Repack-Cooling Slot-In (Zwart)
CODE: 45002 - SKU: 10025
LED 5mm Ultra Helder Rood
CODE: LED30R - EAN: 5060175582065
Plexi G1/4 Belichtingsmodule
CODE: 46006
Phobya DC12-260 12Volt Pump
CODE: 49070 - SKU: 49070
EK-Ekoolant Blood RED premix 1000mL
CODE: 999610 - SKU: 3830046999610
Masterkleer - HighFlow - 1/2 ID - 5/8 OD - UV Red
CODE: 59085 - SKU: 59085
13MM (1/2) EK High Flow Fitting - G1/4
CODE: 996015 - SKU: 3830046996015
Slangklem 12MM - 20MM (7/16 - 1/2) RVS Zilver
CODE: W9-20451
Revoltec Ultra Bright Cold RED Light - 30cm
CODE: RM017 - SKU: RM017
AC Ryan RadGrillz Thrust 2x120 Black ACR-RG30151
CODE: ACR-RG30151 - SKU: ACR-RG30151
Arctic Silver Ceramique Koelpasta (2.5g)
CODE: 31009 - SKU: CMQ-2.5G
PSU Bridging Tool 24 pin
CODE: BP-WTP-J02 - SKU: BP-WTP-J02 - EAN: 4711946731137
B R9-290x system, Advise for watercooling setup please Advies Waterkoeling Setup 0
J Hulp watercooling setup Advies Waterkoeling Setup 75
J watercooling setup mijn eerste ! Advies Waterkoeling Setup 1
Tokke WaterCooling Setup Ivy bridge 3770k Waterkoeling 4
R Watercooling Setup < -€1000 Advies Waterkoeling Setup 18
T Watercooling: Iets in de setup veranderen Waterkoeling 3
P Nieuwe Watercooling setup Advies Waterkoeling Setup 1
P €200,- Core i7 920 watercooling setup Advies Waterkoeling Setup 7
F Mijn eerste watercooling setup Waterkoeling 25
D watercooling setup help Waterkoeling 22
T 1e watercooling setup 800d sli 580 2600k Advies Waterkoeling Setup 31
E watercooling setup Waterkoeling 16
M Advies/benodigheden watercooling setup Advies Waterkoeling Setup 15
R Watercooling setup advies Advies Waterkoeling Setup 2
J Watercooling Setup Advies Waterkoeling Setup 28
K watercooling setup loopt leeg? Waterkoeling 6
