Sleeving Guide (Molex / 24PIN / 4+8PIN / Etc.)
Source
Mr. Grillmeister
PLEASE NOTE that you do this at your own risk - I take no responsibility for burnt out psu's, mobos etc
Now before we get started there is one thing I MUST point out and that is that most power type cables tend to inter-twine - in other words the cable that is in the left most hole at one end may not be in the same position at the other end. I HIGHLY recommend that you take your time and do each cable one at a time (if you are grouping cables make sure you label them accordingly so you do not forget their order) because if you get the order incorrect when you go to power up the next time there is a very good chance you will see the magical black cloud!!
The sleeving used in this guide is all 1/8" Techflex PET
First thing first and that is you need to decide what exactly do you want to sleeve. Are you going to just do the 24 pin cable? Or are you going to do the pcie, fan, molex and the whole shebang. Next step is to work out if you are going to be doing them individually or in groups. This then helps you work out what size sleeving is going to suit your needs. For individual power cable sleeving and fan sleeving I find that 1/8" sleeving is perfect. But once you start moving into groups it all comes down to how many per sleeve you are trying to do.
Now that you have selected your sleeving size/colour options you are going to need some tools to remove the pins from the various plugs.
For all non molex type plugs you can use tools like the ACRyan one below but I found that they have a tendency to break fairly easily. Actually the easiest thing to use is some standard staples....yes staples:ROTF:
I find that two together once bent into shape are a perfect fit for removing those pesky plugs and if you break them...simply get a couple more:thumbup:
What you do is simply place either the pin remover or staples in the end of the plug like so
and then push them in as far as they go (this is where you are likely to break the tools) and then pull on the cable. You shouldn't need too much force but some are a little harder to remove than others.
example of two removers one broken
Just pull on the appropriate cable
To demonstrate your goal at this step Moogle drew up the below diagram to better help explain the process (image courtesy of Moogle @ Hexus.net)
The next step from this point is you take some heatshrink cut to an appropriate length so that when you heat it up it will cover both the end of the sleeving but a section of cable as well. You take this and slide it onto the cable followed by the sleeving.
Once you have moved the sleeving almost to one end guide the heatshrink over the end of the sleeving so that there are no stray wires sticking out.
Now this part will require some nimble fingers and patience if you are using 1/8" heatshrink with 1/8" sleeving as it takes a little bit to get the heatshrink on. But once it is on there it is less likely to come off than if you had used a larger size that doesnt shrink enough to get a firm grip.
Once you have done this end you can either use a heatgun or the missus hair dryer :up: to heat the shrink up so that it keeps the sleeving in place. Do the same at the other end and once that cable is done simply click it back into place within the plug like so.
Now trust me when I say that at first you will probably find it a little difficult and you will probably get frustrated. But if you persist you can get some excellent results.
Here are some quick examples of some I have done recently.....
Deze Guide is gemaakt door Dangals @ XtremeSystems forum.
This thread is made by Dangals on XtremeSystems Forum, for original thread, see here.
Vond het wel handig om hier te posten. :)
Is het trouwens iemand gelukt om het pinnetje met krimpkous en al in de connector te steken?
Bij mij lijkt het wel of het op een gegeven moment niet meer verder krimpt. Ook als ik een stukje krimpkous los verwarm stopt het op een gegeven moment met krimpen.
Source Zelf kabels maken en Sleeving Guide (SATA / Fan Cable / ATX / GPU etc.) Handleidingen en Installatie Tips 78
P Gratis af te halen / over te nemen; custom sleeving Cases en Modding 1
P zelf cable sleeving Cases en Modding 1
S Sleeving cables Cases en Modding 6
Freddy Cablemod AIO Sleeving kits en Addressable LED strips HighFlow Product Suggesties en Nieuws 0
Skozaa Betreft: Cable Sleeving Cases en Modding 4
AQuAKiNG E22 Teleios Premium Sleeving HighFlow Product Suggesties en Nieuws 4
J sleeving en cabelmanagement Cases en Modding 1
G Corsair ax760i, cable sleeving Cases en Modding 0
C sleeving. Cases en Modding 1
F Krimpkous sleeving Cases en Modding 6
k.3nny [GEZOCHT]20m zwarte sleeving Gevonden 0
U Advies omtrent fancontroller en sleeving Cases en Modding 4
k.3nny [INACTIVE] Antivibe rubbers, LIANLI Baycovers/fangrills, sleeving. Verkocht 5
W Sleeving tool kit Lamptron of Sunbeam? Cases en Modding 7
R Sleeving PSU Vraag, Tips, suggesties? Cases en Modding 2
Sw333t [FANS] 2x San Ace fans met MDPC-X sleeving Verkocht 6
Wouter Vraagje over sleeving. Cases en Modding 7
Mobomonster Sleeving - kwaliteitsverschillen Cases en Modding 19
Mobomonster Vinyl Dye ipv sleeving Cases en Modding 11
B Mod/Smart sleeving kits HighFlow Product Suggesties en Nieuws 7
M MDPC-X sleeving HighFlow Product Suggesties en Nieuws 4
Thierry Sleeving tools HighFlow Product Suggesties en Nieuws 4
RRPhantom A.C. Ryan Sleeving+Tools HighFlow Product Suggesties en Nieuws 27
S Sleeving en Heatshrinks HighFlow Product Suggesties en Nieuws 7
Source TechFlex Sleeving HighFlow Product Suggesties en Nieuws 52
Xelation Carbon Fiber Sleeving HighFlow Product Suggesties en Nieuws 18
ZwerverRoodbaard Sleeving HighFlow Product Suggesties en Nieuws 51
Wouter Sleevs/sleeving voor kabels. HighFlow Product Suggesties en Nieuws 5
Freddy Visual Pinball Installatie Guide Virtual Pinball / Flipperkast 0
D Bf3 guide/tips/tricks video's Gaming 0
C Cartago small radiator's Guide Waterkoeling 0
Blackruby Beginners Guide To Water Cooling Handleidingen en Installatie Tips 9
Source A quick guide to SysProfile Gallery & Build Logs 1
R Droogijs Guide: Overclocken met Droogijs Overclocking 18
Xtrafresh Review and use guide: mCubed FanAMP HighFlow Product Reviews 23
D The Nexus 120mm fan corner cutting guide... Handleidingen en Installatie Tips 0
E Howto OC guide: Reg-edit/hardware.info vragen Overclocking 17
Don_Holio Core I7 overclocking guide Overclocking 0
J Howto OC guide: Reg-edit/hardware.info Overclocking 21
Freddy Howto Guide: Overclocking C2D/C2Q Processors (v1.4) Overclocking 10
S 5,7,12 V Molex adapter HighFlow Product Suggesties en Nieuws 2
ProAce [GEVONDEN] Molex > fan adapter Gevonden 1
