Wouter,
Thank you for your visit to our website,
www.techflex.com, and your interest in our expandable sleeving products.
I am sending you samples of our 1/2" Clean Cut and 3/4" Clean Cut, so you can decide which size best fits your application. The nominal sizes that we assign to our sleevings, are the diameters that they will best fit. They are designed to be able to get larger than what you are covering, for easy application, and be able to get smaller, for a tight fit. What you are covering should be somewhere in the middle of the size range.
Contact me after you have had a chance to look over the material, so I can answer your questions and address any of your concerns.
For your convenience, we have a distributor of our products in Germany, Techflex Germany, who can answer your questions and supply you with our products. Your contact is Reiner Ludorf, who can be reached at 492 207 8490 or r.luedorf@techflex.org.
Purchases may also be made from our on-line distributors in the USA, who can be found under the tab Online Dealers.
Let me know if there is anything else I may help you with.
Thanks,
JoEllen Ramsay
Techflex, Inc.
Sales
