GTX 980 waterblokken
Naam product
EK-FC Terminal Plexi
Link
EK-FC Terminal - Plexi
Foto's
Tekst
EK-FC Terminal - Plexi is a translucent replacement connecting link for any EK-FC (Full Cover) water block utilizing FC Terminal type fitting manifold.
EK-FC Terminal - Plexi is CNC machined from solid piece of cast acrylic glass and the externals are machine-polished for glass-like finish.
Enclosed:
- EK-FC Terminal - Plexi
- Allen key 2.5mm
- 2x spare gaskets (OR 15x1)
Made in Slovenia - Europe!
PLEASE NOTE:
- The FC Terminals are not compatible with Original CSQ design full cover water blocks!
- Do not use excessive force when re-tightening the screws as the threads might get stripped thus rendering the water block useless.
R EK-FC GeForce GTX FE 980 ti Waterkoeling 1
Freddy GTX 980 Ti waterblock = Titan X waterblock HighFlow Product Suggesties en Nieuws 0
Ubbidude [Waarde bepaaling] MSI GTX 980 Gesloten 7
M Aquacomputer Kryographics GTX 980 Acrylic Glass edition, Nickel plated version HighFlow Product Suggesties en Nieuws 5
Tath Bitspower Blokken voor de GTX 980 "Nice color led in it" HighFlow Product Suggesties en Nieuws 4
P Advies waterkoeling €1000 ,Core i7 980 X ,RexIII (NB SB), 2x Gtx 480 Advies Waterkoeling Setup 39
Wasmachineman_NL Hardware Labs GTX radiators in ongewone maten (80/160 en 92/184mm) HighFlow Product Suggesties en Nieuws 1
R [Waterkoeling], €300 euro, i5-8600K, nVidia GTX-1080ti Waterforce Advies Waterkoeling Setup 4
0 [Waterkoeling] Luchtdichte-anti-kattenharen-case, 1000 euro, i7 8700K, GTX 1080Ti Advies Waterkoeling Setup 9
XenoMorpH EK-FC1080 GTX Ti Strix - Acetal+Nickel HighFlow Product Suggesties en Nieuws 4
F GTX 1080 hydro copper Waterkoeling 1
P GTX 1080 waterkoeling tips? Waterkoeling 4
S Waterkoeling 300 euro GTX 970 I5 2320 Advies Waterkoeling Setup 3
MisterIce Ek-fc780 gtx wfc HighFlow Product Suggesties en Nieuws 4
Bjorn@demichiel.nl Waarde GTX 690 Gesloten 9
Ahtlon EK-FC780 GTX Ti heeft een bruin kleurige plek op de gpu kanaaltjes Waterkoeling 3
AQuAKiNG waterblock voor gtx 970 hof HighFlow Product Suggesties en Nieuws 6
Tath Bitspower EVGA GTX 970 Supercloked VGa Card HighFlow Product Suggesties en Nieuws 0
0 [Waterkoeling] €500.-, I5-3570K, 2x GTX 660 Advies Waterkoeling Setup 4
l3p [Giveaway!] Corsair Neutrylic GTX 120GB Algemene Discussies 6
Slader EK-FC980 GTX Strix - Nickel HighFlow Product Suggesties en Nieuws 6
