EKwb - Fittingen
Cygnitr0n
Hallo Freddy,
Kan je deze leveren? :050: Deze zijn Black Nickel.
EK-PSC Adapter 90° G1/4 Black Nickel
Revolvable angled adaptor (90°) with G1/4" threads
Adapter allows connection of fitting with G1/4" threads to extend tubing possibilites in your watercooled case.
Technical specifications:
Material: made of nickel plated brass
Threads: G1/4" outer thread - G1/4" inner thread
Sealed with high quality NBR oring.
ROHS compliant!
http://www.ekwaterblocks.com/shop/accessories/fittings/ek-psc-adapter-90-g1-4-black-nickel.html
EK-PSC Adapter 45° G1/4 Black Nickel
Revolvable angled adaptor (45°) with G1/4" threads
ROHS compliant!
http://www.ekwaterblocks.com/shop/accessories/fittings/ek-psc-adapter-45-g1-4-black-nickel.html
G FS: Bitspower, EKWB, Koolance en Barrow Fittingen en koppelingen Koeling 0
J [VERKOCHT] EKWB fittingen. + TFC uv tube. Verkocht 2
foxbuster [TKA] EKWB Waterblock Koeling 1
Hightower EKWB ram waterblokje. HighFlow Product Suggesties en Nieuws 4
Enola EKWB predator 360 QDS expand Advies Waterkoeling Setup 54
Willius Ekwb 970 Strix waterblock Waterkoeling 7
WiSK EKWB HDC fittings HighFlow Product Suggesties en Nieuws 6
Freddy Nieuwe EKWB Supremacy EVO CPU waterblokken! HighFlow Product Suggesties en Nieuws 1
F Lekke ekwb res x1 Problemen & Oplossingen 2
J ekwb "WF3" blocks HighFlow Product Suggesties en Nieuws 6
G EKWB FC780 GTX TI Nickel (Original CSQ) & backplate HighFlow Product Suggesties en Nieuws 2
I EKWB cooling configurator fc6870 Waterkoeling 18
XenoMorpH EKWB EK-FC R9-290X DCII - Nickel HighFlow Product Suggesties en Nieuws 11
H EKWB-CSQ fittings HighFlow Product Suggesties en Nieuws 2
N EKWB FC7970 DCII blok: Fitting aansluiting, alleen boven? Waterkoeling 1
Hightower ekwb backplate titan se HighFlow Product Suggesties en Nieuws 5
l3p [VERKOCHT] Diverse EKWB - XT en XTX Radiatoren (240-360-480) Verkocht 2
S EKWB Res Waterkoeling 2
H [gevonden] ekwb hd 5870 v2 Gevonden 5
Sanders [VERKOCHT] 2x Asus GTX580 1,5 Gb + EKWB oud model Verkocht 3
z999 [VERKOCHT] Asus 5870 MET ekwb waterblock (nikkel acetal) en backplate + carbon look Verkocht 10
l3p [VERKOCHT] Diverse EKWB CoolStream XT Radiator Verkocht 1
G EKWB Fitting HighFlow Product Suggesties en Nieuws 1
psyduck170 EKWB introduces CSQ design HighFlow Product Suggesties en Nieuws 128
Asphiax [IN-ACTIVE] 580 GTX reference EKWB acetal +nickel waterblock Gevonden 7
S Geschikt EKWB gpu block voor mijn Sapphire HD5570 1GB Waterkoeling 9
BETA911 [INACTIVE] EKWB (Copper + Acetal) HD4870X2 Verkocht 7
Jason 60% SALE 🏷️ op Coolforce CF1 Compressie/ Adaptor Fittingen HighFlow Product Suggesties en Nieuws 0
