EKWB HDC fittings
WiSK
Naam product
EK-HDC Fitting 12mm G1/4
Links
EK-HDC Fitting 12mm G1/4 - Nickel
EK-HDC Fitting 12mm G1/4 - Black Nickel
EK-HDC Fitting 12mm G1/4 - Gold
EK-HDC Fitting 12mm G1/4 - Red
EK-HDC Fitting 12mm G1/4 - Blue
Foto
Kan nog meer foto's uploaden zo nodig!?
Tekst
EK-HDC Fitting is a solid-tube compression fitting, designed for use with solid tubing such as Acrylic, Copper, Stainless Steel or any other type of compatible hard tube.
EK-HDC Fitting is a more secure variant of the EK-HD Adapter fitting as it prevents solid tube to be pulled out of the fitting by compressing the rubber gasket underneath the ring.
The barb and the ring are made of nickel-plated CNC machined brass with quality O-rings. These fittings are fully compatible with EK-CSQ series (45°/90°) angled adapters.
Best practice is to install these fittings using Allen Key 9mm (not included, available for separate purchase).
Technical data:
- thread: G1/4" BSP; 4.5mm male thread lenght
- supported tube: 12mm (OD)
- outer diameter of a fitting: 18.8mm
- installed height: 17mm
- compatible tubing: solid Acrylic-, Copper-, Brass- or Stainless Steel tube
ROHS Compliant!
Made in Slovenia - Europe!
PLEASE NOTE:
- Please wet the gasket (o-ring) using drops of water prior to installing solid tube.
- Do not use excessive force when inserting solid tube!
- It is mandatory to chamfer the edges of freshly cut solid tube in order to prevent gasket (o-ring) damage. EK recommends a 0.5mm x 45° chamfer.
Yes deze gaan we z.s.m. toevoegen.
Had jij al mss enkele nodig? Zo ja, kan je aangeven welke, dan kunnen we die alvast op de bestellijst zetten en op voorraad houden ;)
Dat is lastig, sorry! :schaam
Ik heb laatst een nieuwe behuizing gekocht, een nieuwe voeding besteld, denk wel te weten welk moederbord ik kies en binnenkort is er de GTX980...
Maar thema kleur voor de build is nog helemaal open. Meestal doe ik zwart of wit of blauw, maar misschien eens een keer nikkel of rood. Hmm :help
Heb ze nu niet nodig, maar heb wel een witte build waar ik misschien over wil naar acrylic. Vandaar...
Naam product
EK-HDC Fitting 12mm G1/4 - White
Link
Foto's
Tekst
The barb is made of black nickel-plated CNC machined brass while the ring is made of CNC machined, white anodized aluminum with white paint finish and feature quality O-rings. These fittings are fully compatible with EK-CSQ series (45°/90°) angled adapters.
Technical data:
ROHS Compliant!
M EKWB Waterkoeling 3
Hightower EKWB EK-Nucleus AIO CR240 Lux D-RGB en CR360 HighFlow Product Suggesties en Nieuws 22
P Levertijd EKWB HighFlow Computer Cooling Shop 2
D EKWB Quantum Surface Radiators HighFlow Product Suggesties en Nieuws 3
Hightower EKWB ram waterblokje. HighFlow Product Suggesties en Nieuws 4
Enola EKWB predator 360 QDS expand Advies Waterkoeling Setup 54
Willius Ekwb 970 Strix waterblock Waterkoeling 7
Freddy Nieuwe EKWB Supremacy EVO CPU waterblokken! HighFlow Product Suggesties en Nieuws 1
F Lekke ekwb res x1 Problemen & Oplossingen 2
J ekwb "WF3" blocks HighFlow Product Suggesties en Nieuws 6
G EKWB FC780 GTX TI Nickel (Original CSQ) & backplate HighFlow Product Suggesties en Nieuws 2
I EKWB cooling configurator fc6870 Waterkoeling 18
XenoMorpH EKWB EK-FC R9-290X DCII - Nickel HighFlow Product Suggesties en Nieuws 11
H EKWB-CSQ fittings HighFlow Product Suggesties en Nieuws 2
N EKWB FC7970 DCII blok: Fitting aansluiting, alleen boven? Waterkoeling 1
Hightower ekwb backplate titan se HighFlow Product Suggesties en Nieuws 5
l3p [VERKOCHT] Diverse EKWB - XT en XTX Radiatoren (240-360-480) Verkocht 2
S EKWB Res Waterkoeling 2
