[User-Review] Phobya G-Silent 18 700rpm RedLed im Cartago´s Review
cartago2202
Phobya G-Silent 18 700rpm Red LED im Cartago´s Review
Hello and welcome to my new Review
Introduction:
Today I'm going to, for you, the new 180mm fan Phobya of the "teeth feel"
This new fan series is only recently come onto the market and would,
like the 180mm aperture for Nova1080 radiator, so to speak from my idea developed out.
It is very enjoyable to see a manufacturer that implements the ideas
and suggestions of a user and of course the realities of the market in new products.
The fact that the development and production is not "from now on after" happened so normal,
so there are already past couple of months since I've turned to Phobya and the fans have finally come to market.
But now they are there and need to compete in this test against the Phobya Nano-G 120 PWM.
Optical appearance:
Phobya Returns the fans in their typical red-blue-black packaging,
marked with the Phobya logo and name on one side and the technical data on the other side.
The fans themselves have a matte black frame and red rotor, but this time,
as opposed to the 120 G-silent, the fan blades in a much darker red and are not as clear and transparent.
Unfortunately, the connection cables are not covered, which can be taken negatively on the one hand and on the other hand,
the modders among us to be the cables themselves, in favorite color to sleeving.
The supply is limited and consists of just four mounting screws.
The four built-in LEDs has Phobya, in my opinion, very well chosen,
they are not too bright and thus fit well with the dark-red fan blades.
and the Nano-G 120 PWM
Technical details:
Dimensions: 180 x 180 x 32mm
Colors: Black frame, red wing leaves, red LEDs
Weight: 432g
Rated Voltage: 12V
Start Voltage: 7 Volts
Power: 3W
Rated speed: 700rpm (+ / -10%)
Airflow: 169 m³ / h / 100 CFM
Noise level: 18 dB / A
Connector: 3 Pin Molex
Feature: 4x red LEDs
Delivery:
1x Silent Phobya G-18 700rpm Red LED (180x180x32mm)
1x 4 black fan screws
Test system and test procedures:
Motherboard: Asus Maximus Formula III
CPU: Intel i7 860 @ 4GHz @ 1.425 V (Bioseinstellung)
CPU coolers: CPU water cooler Phobya
RAM: Corsair Vengeance 8GB Kit PC3-12800 9-9-9-24 (DDR3-1600)
Grafik: PowerColor HD6950 @ 6970 with Koolance VID-AR697
NT: be quiet! Dark Power Pro 850W P9
Koolance TMS-200 controller
Koolance INS-FM16 Flow Sensor
2x Koolance Temperature Sensor SEN AP006G
1x Koolance Temperature Sensor SEN AP002P zuständigt for the room temperature
Laing ultra pump with Alphacool Laing DDC Reservoir and top combo Rev.2
Alphacool Slot plate HF38 Panama
2x Phobya couplings
Masterkleer hose 16/10 Dark Red
Phobya Radiator Stand 9x12/4x180 Bench Edition
Phobya Nova 1080 with 120mm and 180mm aperture
Phobya ZuperZero Pure Water
For the utilization of the CPU caused the program Prime95 (small FFT's) in the latest version and the video card Furmark.
The temperatures were recorded after 60 minutes running.
For logging the Koolance Thermal Management Software v2.1 was responsible.
Since in my test is to improve the efficiency of the fan,
only the temperature difference would be taken into consideration water to air.
This value shows the best performance of the cooling fan, the less pronounced this difference,
the better the existing room air to cool the water used in the radiator.
For both fans varieties of three measurements are made ​​with 5V, 7V, 12V.
The results will lead me clearly in a table together to reduce clutter are no extra values​​.
Room temperature was almost always constant at about 22 ° + / - 1
Test results:
All values ​​+ - 1 ° for the tolerance
Idle:
Load:
Conclusion:
As can be seen in the tables, the G-Silent 180, almost in every shot,
better than the nano-G 120, although the difference is not so big that it would affect
the system but the species is already clear.
The silent G 180 perform, in any tension, their work significantly quieter than the nano-G 120 and the wiring is much smaller.
Of the 8pcs. The running has made ​​me Phobya for this review available seven without any background noise,
and one developed only in the lowest level, around 250rpm, a light grinding of the covers from about 500rpm but quietly through the air noise.
From a distance of about 50cm but the noise is not noticeable.
At 12V, the cooling performance, despite the low speed of about 750rpm, and the huge air noise has discreetly been limited.
This performance and the very good workmanship coupled with the pretty decent design,
I can only with the coveted "Cartago's Review" Award in honor of gold.
Acknowledgments:
I would like to especially Phobya and Alphacool thanks for providing the test sample, the support and trust have placed in me, and the company Asus, Intel, Corsair, PowerColor, be-quiet!, Koolance for their kind support.
bundymania [Bundymania User Review] English Version: Mora 2 / Mora 3 / Phobya Nova 1080 ! HighFlow Product Reviews 6
bundymania [Bundymania User Review] Drobo 5N2 NAS (GER) HighFlow Product Reviews 0
bundymania [Bundymania User Review] K-GK 1 mechanische RGB Gaming Tastatur von KM-Gaming ! [GER] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Tesoro Gram Spectrum - mechanische Gaming Tastatur [GER] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Externe 3 TB Festplatte - TOSHIBA Canvio Premium [GER] HighFlow Product Reviews 0
bundymania [Bundymania User Review] InnoWAVE Plus - Over The Ear Headphones (German) HighFlow Product Reviews 0
bundymania [Bundymania User Review] UGOOS UT4 Android Media TV Box (GER) HighFlow Product Reviews 0
bundymania [Bundymania User Review] FNATIC Gear Mauspads [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] WASDkeys K200 Gaming Keyboard HighFlow Product Reviews 0
bundymania [Bundymania User Review] WASDkeys M100 Gaming Mouse [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] GeIL EpicGear Morpha Gaming Mouse [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Fnatic Gear Rush G1 Backlit Mechanical Keyboard [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Alphacool Eiszapfen Anschlüsse und Adapter in der Übersicht HighFlow Product Reviews 1
bundymania [Bundymania User Review] QPAD 8K Pro Gaming Laser Mouse [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Mionix Castor Optical Gaming Mouse [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] INNODevice INNOFlask 2.0 Bluetooth Speaker [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] EpicGear GeKKota Ambidextrous Laser Gaming Mouse [deutsch] HighFlow Product Reviews 0
bundymania [User Review] Corsair Strafe RGB - mechanische Tastatur mit MX-RGB Silent Switches HighFlow Product Reviews 0
bundymania [Bundymania User Review] Arctic P614 BT Bluetooth Headset (deutsch) HighFlow Product Reviews 0
bundymania [Bundymania User Review] Shogun Bros Ensense Gaming Headset [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] RANTOPAD Mauspad Roundup [deutsch] HighFlow Product Reviews 0
Consigliere [Consigliere User Review] Scythe Fuma HighFlow Product Reviews 2
Consigliere [Consigliere User Review] Silent Base 800 van BeQuiet HighFlow Product Reviews 1
Consigliere [Consigliere User review] HighFlow Product Reviews 0
ProAce [ProAce User Review] In Win 703 HighFlow Product Reviews 4
bundymania [Bundymania User Review] Alphacool D-RAM Cooler X4 (für Corsair Dominator™ RAM) HighFlow Product Reviews 0
bundymania [Bundymania User Review] CM Storm PULSE-R Gaming Headset [Deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] CM Storm HAVOC Gaming Mouse (English) HighFlow Product Reviews 0
bundymania [Bundymania User Review] CM Storm HAVOC Gaming Mouse [Deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] 4x 1080 Monster Radiators [English Version] HighFlow Product Reviews 0
bundymania [ User Review ] Swiftech MCP35X + D5 PWM Pumps HighFlow Product Reviews 0
bundymania [Bundymania User Review] Triple Radiator (360) Roundup with 22 Rads ! HighFlow Product Reviews 0
bundymania [Bundymania User Review] 6 Waterblocks for HD7970 - Roundup - ENGLISH Version HighFlow Product Reviews 1
C [User-Review] Complete Set: Swiftech H2O-320 kit in Cartago's Edge Review. HighFlow Product Reviews 2
bundymania [Bundymania User Review] Streacom F7CB - ein neuer Stern am HTPC Himmel ?! HighFlow Product Reviews 4
C [User Review]ApogeeHD vs. RAYSTORM vs.Kryos vs. SupremeHF in Cartago´s Review HighFlow Product Reviews 0
