Cartago´s Quad-Radiator Roundup
cartago2202
Hello and welcome to all of you to my new Quad-Raditator-Review.
After my small Radiator-Guide I would like to introduce you a new Roundup of Quad-Radiators, which includes eight Radiators. You can mount up to four 120mm Fans on this Radiators, but they do not fit in many PC-Cases.
The available Roundup includes Models from the most famous producers and ranges from the beginner model to the high-end-Models. We have the extreme slim Koolance Vertikal with 30mm up to the 60mm thick Monster-Models from Phobya, XSPC, Thermochill and Coolgate.
I focused in this test three of the most popular fan speeds, which were realized by 600u/min, 900u/min and 1200u/min. In my opinion a test with more than 1200u/min does not make any logical sense, because a watercooling-solution should cool the components at low noise-level. I introduce as well a new style of rating-system with this review and divide the the final conclusion in two categories. These two categories consist of [1] the pure cooling capacity and [2] the processing quality and the ratio of price and performance. For example it does not make any sense for me, if the Radiator has a superb processing quality but a low cooling capacity. The same applies the other way, the performance is above everything?
Let us take a closer look at the candidates:
Here are the Test candidates in alphabetical order:
Coolgate Copper Radiator 480mm.
Technical Information:
Material: Copper fins, brass chambers, Tubes with extremely high copper content.
3 Water boxes 13 x 2mm
Color: Black
Size (L xB x H): 533,6 x 124 x 60mm
Fittings: G1/4 Zoll
Thread Size oft he Screws: 6-32 UNC
Weight: 1780g
Fluid Volume: 500ml
Tested pressure load: 1.5bar
Fan Size: 120mm
Further Specials: Fill the connecting thread at the bottom for light / vent.
Delivery Content:
1x Coolgate Copper Radiator 480mm
16x UNC 6-32 x30mm Schrauben
4x Mounting Screws
4x Entkopplung
The Radidators, which are built by the company Coolgate, are quite new to the market. Coolgate tries to appeal to high-end-customers. As the addition of "Copper" in the name suggests, is to bring the high copper content above average performance. Whether it's true, the tests will have to prove.
The Radiator comes in a very noble and comprehensive packaging. The packaging includes short and long screws and additional anti-vibration-frames for the fans, which would make any slient-freak happy.
In terms of looks and build quality Coolgate sets a very high bar. That should not surprise, if you take a look at the price. The painting is executed well and the plates are smooth and error free. Four G ¼ allow virtually any installation option, both horizontally and vertically. At the back of the radiator you can find another G ¼ Port, which you can use for fill and bleed. Unfortunately, the manufacturer has decided to use UNC screws. Although they are included here, depending on the installation position they can be too short or too long. The user should therefore be aware of the mounting position and should buy before screws with appropriate lengths.
EK-CoolStream RAD XT 480:
Material: Copper, Brass.
Color: Black
Size: 520 x 123 x 47mm
Fittings: 1/4Zoll
Fan Thread Size: M3
Weight: 1.595g
Delivery Content:
1x EK Water Blocks EK-CoolStream RAD XT 480
16x M3 x 30mm Screws
16x M3 x 35mm Screws
The company EK-Waterblocks, which is known for their CPU and GPU-Watercooling-Solutions, is producing since a short period as well Radiators. The Radiator from EK comes in a two-piece package. The outer part shows the well-known EK pattern. The Radiator comes with screws with two different lengths and is located in the inner white box.
The processing is fairly decent but not up to the gate of the Coolgate Radiators. On the side you can find the embossed EK-Logo. The paint is free from errors.
Koolance Radiator 4x120mm Vertikal:
Fittings: 1/4"
Size: (B x H x L): 12,6cm x 3cm x 51,5cm
Fan Thread Size: M4
Weight: 1000g
Lieferumfang:
1x Radiator
12x M4x32mm Screws
1x pair 6mm-Connection-Extensions, inward and outward thread
Koolance, which is formally better known for their high-end Mainboard-Watercooling-Solutions, comes in this test with the HX-CU1320V Radiator. The Radiator comes in a simple box, which does not guarantee enough protection for a Radiator. Therefore the test sample shows a small bump . The processing quality is not the very good. You can find small painting errors and a few bent fins. The Radiator shows on the side the Logo of the producer. The delivery content consists of the few screws and the connection-extensions.
With the 30mm the radiator is the thinnest candidate in this review. The manufacturer has chosen a very narrow fin spacing in order to increase the radiator surface. In the further review we will see, if this decision can increase the performance of the Radiator.
MagiCool XTREME QUAD 480 Long:
Technial Information:
Material: Copper fins, Brass
Size: (L x B x H): 520 x 120 x 47mm
Fittings: G1/4"
Weight: ca. 1560g
Mounting-Options: 16 x M3-Threads at the top (for 8x 120mm-Fans),16 x M3 Threads at the bottom (for 8x120mm-Lüfter)
Pressure tested: 8 Bar,
Ports: 2x Gewinde G 1/4 Zoll
A seasoned size in the watercooling sector is certainly MagiCool Xtreme. The Radiator comes in simple box and is well wrapped with foil. The delivery content consists of the most necessary items. The fan cover of the Radiator is colored in silver and has as well bar-fans on the sides. The bar-fans are covered with foam rubber, which should prevent turbulence of the airflow. The processing quality is good. The sharp edges of the aperture disturb the good overall impression. The protective film on the end pages cannot be removed without trace.
Phobya Xtreme QUAD 480:
Size: (L x B x H): 264x242x46mm
Fittings: G1/4"
Weight: ca. 1567g
Mouting-Options: 16x M3-Threads at the top (for 4x 120mm-Fans)
Pressure tested: 2 Bar,
Delivery Content:
1x Radiator
16x M3x30mm Screws
The next test candidate is the Phobya Xtreme QUAD 480 Radiator. This differs fundamentally from conventional radiators in its design. It's not like the candidates remaining longitudinally mounted but has a square shape. The Radidator comes in a well-protected colorful painted box, which is typical for Phobya. The processing can be described as good to very good, all fins are straight and the ports are clean set. Only the fan screen itself bears traces of processing. Fans are attached to this Radiator with an aperture, which you can buy now completely in black. You can as well moun the Radiator in the Phobya Radiator-Rack, which is a great option in my opinion.
Phobya G-Changer 480 ver. 1.2 Black:
Color: matte black
Size: (L x B x H): 532x125x60mm
Fittings: G1/4"
Weight: ca. 2100g
Mounting-Options: from both sides
Thread Size: M3
Fan-Size: 4x 120mm
Pressure Tested: 2 Bar
Additionals: Bleed Screw
Delivery Content:
1x Radiator
16x M3x30mm Screw
4x Anti-Vibration
2x black screw plugs
The G-Changer 480 Ver. 1.2 Black comes in a well-protected colorful painted box, which is typical for Phobya. The Radiator is well protected by foil. The delivery content is extensive and consists of Screws in the lengths 30mm, 35mm and 10mm, four anti-vibration-frames, and two screw plugs. The quality of the painting and the processing quality is very good. The paint wears in some places clearly traces of bubble wrap. This radiator has the same gate as the Coolgate radiator, four G 1 / 4 connectors, two horizontally and vertically. At the other end of the radiator has an additional vent screw. On the side you can see the embossed Phobya Logo.
Swiftech MCR420 QP:
Technical Details:
Fittings: G1/4"
Size: 521 x 128 x 34mm
Weight: 1100g
Thread-Size: UNC 6-32
Delivery Content:
1x 480mm Radiator
Mounting screws
Different than the name would have suggested, this Model is a 480mm radiator. The American manufacturer Swiftech is one of the so-called "big players" on the water cooling market. Unfortunately, he's here with us not as common, because of the exchange rate from Dollar to Euro. The Radiator comes in a brown box. The radiator itself is also in a kind of two-piece bag,
which is to protect it from damage. The processing quality is very good and the painting shows no errors as well. The delivery content consist just of the necessary screws and a warning sign in german language.
Thermochill TA120.4:
Color: matte black
Fittings: 1/4"
Weight: ca. 2,5 kg
Seize (LxBxH): 524 x 129 x 60mm
Delivery Content:
1x Thermochill TA120.4 Quad Radiator - 480 Radiator
16x 13mm Self-tapping screws
Thermochill has been one long to spearhead the radiators. The models of the PA series were very successful. Unfortunately, these radiators are not as common with us, which may be due to the high legal cost. He comes well protected in plain white packaging. In addition, there are also the self-tapping screws. Unfortunately, the processing quality is only moderate, the paint is not applied correctly and the finish is not very good. Fortunately Thermochill has adjusted its usual format of the connection threads G 1 / 4 ", which was also a major drawback of earlier models.
XSPC RX480:
Color: matte black
Seize: 125x58.5x510mm (BxHxT)
Material: Copper
Fittings: 2x G1/4"
Thread-Size: M4
Screws: 4x M4x10, 16x M4x 30
Specials: 3x water channels in the height
The radiators of the RX series from XSPC have been that of the RX360 Radiator always appear on the front seats to find. The Radiator comes in white box. The radiator itself is wrapped in foil. The package is limited to the obligatory screws. The processing on my copy would be referred to as a super, but there is a little error in the paint. The paint wears in some places clearly traces of bubble wrap. Apparently, two different models are circulating of this radiator, the one that is probably older revision, equipped with UNC 6-32 threads, and the one I got on this comparison, with M4 threads.
The Test system in detail:
Mainboard: Asus Maximus III Formula
CPU: Intel Core i7 860 @ 4 Ghz@1,4V
GPU: AMD ATI Radeon HD6950@6970 @ 1,175V
Memory: 8GB Corair Vengeance CL9
Power Supply: be quite! Dark Power Pro P9 850W
HDD: Samsung F3 500GB
Watercooling Setup:
CPU: Alphacool HF14 Yellowstone CooperEdition
GPU: Alphacool NexXxoS ATXP ATI 6970/50
Pumpe: Phobya DCP-12 400
AGB: Alphacool Cape Corp Coolplex Pro 25
Fittings: 16/10 Alphacool Cooper
DFM: AC DFM HighFlow
Control: Aquaero5 XT
Temperature sensors: 2xPhobya IG/AG ¼ und Einschraubsensor für AGB
Tube: 16/10 Masterkleer
4 quick couplings Koolance VLN3
The new Phobya G-Silent 12 1500rpm Blue Led were used as Radidator fans. Every Setup was tested with three fan speeds, 600rpm, 1200rpm and 900u/min. For all tests, I used the included components of the manufacturer. The tool CoreDamage was used for heating up the CPU and rthdribl was used for the GPU. The Setup ran for one hour and the temperature of air and water was noticed via Aquaero5. The fans were mounted blowing on the radiators.
Here are the results:
Delta T @ 600u/min
Delta T @ 900u/min
Delta T @1200u/min
Flow Lph:
Preis:
Scaling of the individual radiators
Price-performance comparison
Conclusion:​
At first a positive announcment: Every Radidator was able to cool the System. The Koolance Radiator has lower values, because of the tight-fitting fins. The rest of the test field is already as close together, because of the high producing standards of the manufactures. There are two fairly groups, which consist of the midfield EK, Magicool, Phobya Xtreme, and Swiftech, Thermochill. The peak power of this test field, the radiators from Coolgate, Phobya G-Changer and XSPC.
The rear and cut off the Koolance radiator stands alone because, although he has his right to exist but at the expense of the volume. He is, by its small thickness, for people who thought that rely on such thin radiators and want to take the higher volume in sales.
The quality of machining, I was disappointed overall by most manufacturers.
A very large bright spot is the Coolgate radiator, with its excellent quality and great delivery.
Close behind are the two premature packed radiators and Phobya XSPC.
The rest of the test field is plagued with more or less small quality problems, which again stands out of the Koolance negative.
So let us see, which Radiator gets an Award.
Coolgate Copper radiator 480mm gets for the performance and for the quality of workmanship "Cartago's Review Award" in gold.
XSPC RX480 and Phobya G-Changer480 get for her performance a "Cartago's Review Award" in gold and not quite perfect for processing a "Cartago's Review" Award in Silver.
EK-CoolStream RAD XT 480, MagiCool Xtreme480, Phobya Xtreme Quad, Thermochill and Swiftech TA12.4 get all of their performance and quality of each one "Cartago's Review Award" in silver.
Koolance Radiator 4x120mm unfortunately, only gets an award and indeed for the service, as can be seen from the tables
increases the power significantly with increasing speed.
For the performance, there is a "Cartago's Review" Award in bronze for the quality there is no award. Although it could be that I've just caught a bad copy but unfortunately this also requires that package comes out of the radiator to damage in shipping.
Acknowledgments:
I hereby want to thank all the other manufacturers you for support in this roundup, and Guapa @ Hluxx for creating the tunnel diagrams.
C [User Review]ApogeeHD vs. RAYSTORM vs.Kryos vs. SupremeHF in Cartago´s Review HighFlow Product Reviews 0
C [User-Review]World´s First: the new XSPC Radiator EX 360 in Cartago´s Review HighFlow Product Reviews 2
C Cartago´s HD6970 water cooler Roundup HighFlow Product Reviews 0
C [User-Review] Alphacool NexXxoS HD6970/6950-- GTX580/570 im Cartago´s Review HighFlow Product Reviews 1
C [User-Review] Phobya G-Silent 18 700rpm RedLed im Cartago´s Review HighFlow Product Reviews 3
C [User-Review]Alphacool Cape Fuzion Core 30 Acetal Black in Cartago´s Review HighFlow Product Reviews 3
C [User-Review] Alphacool CapeCora HF 1042 im Cartago´s Review HighFlow Product Reviews 1
C [User-Review] Alphacool VPP655 Single Edition pump im Cartago´s Review HighFlow Product Reviews 0
arwin74 Quad sli setje Gesloten 6
L 900D Quad Crossfire Build Advies Waterkoeling Setup 10
webdesigner Iemand persoonlijke ervaringen met de Phobya extreme quad 480 rad ?? Waterkoeling 6
G [CLOSED] Quad core game pc watercooled Gesloten 2
M Socket 775 quad core, DFI lanparty x48, Antec 1200 Advies Waterkoeling Setup 2
Zwelgje [VERKOCHT] Dominator® GT 16GB Quad Channel DDR3 Kit Verkocht 3
Harjo Phobya Extreme quad 480 HighFlow Product Suggesties en Nieuws 7
L Gtx 590 quad connecten met silverstone st1500? Hardware & Software 3
joostgvk Ultra Bright Cold UV Light - 30cm QUAD set werkt niet? Cases en Modding 7
Legendary1985 [TKA] EVGA GeForce GTX 590 Classified Hydro Copper Quad SLI (2 pack) Verkocht 2
alain-s [VERKOCHT] ThermoChill PA120.4 Quad - 480 (15mm) Verkocht 10
VoYaGeRTM Aerocool Streamliner BLACK-w/Quad blue LEDs-EN042383 HighFlow Product Suggesties en Nieuws 4
Quadcore [TKA WC PARTS] Quad & Hayato's ... MEGA SALE !!!! Verkocht 35
fatal_error.be afmetingen ThermoChill PA120.4 Quad - 480 (15mm) Waterkoeling 4
Quadcore QUAD's R56... static lowrider build Overige Builds 664
VuXX Vuxx's +* VuXXinator *+ [Quad SLI GTX295's and Cosmos S] Gallery & Build Logs 73
C UV Light 30cm QUAD set: 1 adapter doet het niet = 2 lichten gaan niet aan. Cases en Modding 11
bundymania REVIEW: Radiator Comparison - TFC X-Changer 480 Quad Radi <-> Mora 2 Pro HighFlow Product Reviews 0
bundymania REVIEW: Quad Radiator Roundup ! HighFlow Product Reviews 1
N Fesser quad rad HighFlow Product Suggesties en Nieuws 6
E quad sli gtx 295 Hardware & Software 29
Quadcore Quad"s Black-edition.nl Gallery & Build Logs 241
W CPU Temps met TFC Quad, Ultra Kaze Fans en MCP350 Waterkoeling 16
D Recom quad led blower 12025BL-LED HighFlow Product Suggesties en Nieuws 7
D D-TEk fusion V1 quad of niet? Waterkoeling 5
W CPU koelblok voor Intel core 2 quad CPU Waterkoeling 4
K Koolance 1/2" or 3/8" - Quad 1/4" ID Tubing Y-Splitter HighFlow Product Suggesties en Nieuws 5
Freddy TFC Xchanger QUAD Waterkoeling 24
Freddy D-Tek FuZion v2 Quad Core Mid Chamber Insert Handleidingen en Installatie Tips 8
B plaatsing radiator Eisbaer pro aurora Waterkoeling 4
Bl4ckj4ck666 radiator gasket Waterkoeling 1
