Problem with mounting HWLabs GTS420 into the top of Meshify 2 XL
Thorrior
Hi all,
I recently bought a GTS 420 at HighFlow and I found out that it doesn't fit into the top mounting bracket of my Fractal Design Meshify 2 XL case. The bracket is L-shaped and there are these small plastic clips that hold the side panel in place. Because of these clips and the width of the GTS 420 radiator it's impossible to mount it to the top bracket. I could mount the fans right under the bracket and the radiator underneath it, but I'm going with RGB fans. So I would have to go for push / pull and I don't want to do that.
Now I was wondering if I could use these Phobya shrouds as a spacer between the radiator and the mounting bracket. Does anyone have a Fractal Design case (Define 7 XL or Meshify 2 XL) together with radiators from HardwareLabs by any chance and knows if this will work? I don't want to order the shrouds just to find out that it still doesn't fit. In this case I would just get another 420 radiator which is not as wide.
Here is a picture of the bracket and the radiator. You can see that the rad touches the clip on the left side because it's a bit too wide.
M Flow rate problem Waterkoeling 10
W Problem whit my XSPC Pomp 2 International Forum 2
Johnny [Problem Solved] Snelkeuze Nokia 1101 **SPOED** Problemen & Oplossingen 2
D Asus O!Play mediaplayer problem(en) Hardware & Software 6
D Software/ Hardware problem Hardware & Software 19
S Ek Supremacy Evo AM4 mounting HighFlow Product Suggesties en Nieuws 1
T Mounting hardware MO-RA3 HighFlow Product Suggesties en Nieuws 4
U Mounting hardware H110 HighFlow Product Suggesties en Nieuws 2
D Bitspower D5 Bracket (Stand) Mounting gaten Waterkoeling 4
Besje EK-DCP mounting plate kit HighFlow Product Suggesties en Nieuws 2
reclamations Mounting plate Supremacy AMD HighFlow Product Suggesties en Nieuws 4
Joren [IN-ACTIVE] Heatkiller s1156/1155 mounting Gevonden 2
S [CANCELLED] LGA2011 Mounting schroeven voor EK Supreme LTX Verkocht 3
S [CANCELLED] ek supreme hf nikkel top 1155 mounting Verkocht 5
Luculenus [VERKOCHT] Apogee HD met LGA2011 mounting kit. Verkocht 16
S Scythe LGA 1156 Mounting for Mugen 2 HighFlow Product Suggesties en Nieuws 5
Thierry Koolance radiator mounting screw and nut HighFlow Product Suggesties en Nieuws 5
F Mounting plate Supreme HF Intel - Nickel HighFlow Product Suggesties en Nieuws 2
B Clear Mounting Tape 3M Scotch #4010 HighFlow Product Suggesties en Nieuws 8
R [INACTIVE] Aqua computer cuplex HD s775 mounting kit Gevonden 5
l3p [VERKOCHT] EK Supreme HF Nickel/Plexi + EK-Mounting plate Supreme Chromera Verkocht 5
The_Saviour# [INACTIVE] Corsair H50 s775 mounting Gevonden 1
Duriel Lian Li Power Supply Mounting Bracket Black : PE-03(B) HighFlow Product Suggesties en Nieuws 4
S [GEZOCHT] Corsair H50 met Socket 775 mounting erbij Gevonden 3
B Xigmatek AMD Vertical mounting kit HighFlow Product Suggesties en Nieuws 11
J question about mounting a Black Ice GT Stealth 280 International Forum 19
coolfris HEATKILLER® CPU Rev3.0 775 Mounting Kit HighFlow Product Suggesties en Nieuws 1
J Mounting voor Black Ice SR-1 560 Waterkoeling 13
vincent *NEW* Koolance D5 Pump Top/Mounting kit HighFlow Product Suggesties en Nieuws 3
M Apogee GTZ s1156 mounting HighFlow Product Suggesties en Nieuws 2
Source SSD Mounting van (UN)Designs HighFlow Product Suggesties en Nieuws 14
Quadcore CPU Block/Blok Mounting kits HighFlow Product Suggesties en Nieuws 5
R d-tek mounting HighFlow Product Suggesties en Nieuws 1
Traxtorm Radiator Mounting Bracket met Quick-Release HighFlow Product Suggesties en Nieuws 3
ChrisdeW D-tek fusion v1/v2 mounting 1366 input nodig Waterkoeling 10
A mounting screws thermochill PA Waterkoeling 7
A XSPC X2O Delta Intel i7 Only Mounting Plate Waterkoeling 3
M EK Supreme Mounting Plate voor i7 - 1366 HighFlow Product Suggesties en Nieuws 3
Xtrafresh HWLabs GTX 120 HighFlow Product Suggesties en Nieuws 4
