question about mounting a Black Ice GT Stealth 280
jcgeny
i want to install a radiator at the top of a zalman gs1000 plus , i want to install inside of the case . i selected 2 "Slip Stream 120 mm Slim Case Fan" as fans i will insert under the top plastic black cover . my question is : will it be possible to use the screws and holes of the 2 fans 120 to attach the radiator that has a size of 2 x 140 or do i need to choose a 2 x120 radiator ?
to be as clear as possible my plan is : top cover black of case then fans , then the metal of the case and the radiator inside.
it is possible with the well know fan adapters (a plastic piece that makes the hole bit smaller and you mount that on your 280 Rad, then you mount 2 120 fans on your adapters. but like most people say, its better to use 140mm fans)
see:
here is my scetch about the situation and why it won't work
at the red circle the adaptors, would hit
so only if you make your own fan holes, or you go backwards (from 140mm fan holes to 120mm) it would work
Yeah that's wright, it depends what the topicstarter wanna do.
Although i dont think he's comming back?
Algemene informatie
Laatste activiteit:19 juli 2010 20:17.
Geregistreerd:19 juli 2010.
like i said :D
R Watermeter bouwen (n00b question) Waterkoeling 5
C Highflow nl web shop (Germany delivery question) HighFlow Webshop 4
Baloo.be EKWB intel Velocity > AM5 Mounting Hardware Waterkoeling 2
A Cooler Master v8 gts AM5 mounting kit. Overige Koeling 3
T Problem with mounting HWLabs GTS420 into the top of Meshify 2 XL Handleidingen en Installatie Tips 3
S Ek Supremacy Evo AM4 mounting HighFlow Product Suggesties en Nieuws 1
T Mounting hardware MO-RA3 HighFlow Product Suggesties en Nieuws 4
U Mounting hardware H110 HighFlow Product Suggesties en Nieuws 2
D Bitspower D5 Bracket (Stand) Mounting gaten Waterkoeling 4
Besje EK-DCP mounting plate kit HighFlow Product Suggesties en Nieuws 2
reclamations Mounting plate Supremacy AMD HighFlow Product Suggesties en Nieuws 4
Joren [IN-ACTIVE] Heatkiller s1156/1155 mounting Gevonden 2
Sw333t [CANCELLED] LGA2011 Mounting schroeven voor EK Supreme LTX Verkocht 3
S [CANCELLED] ek supreme hf nikkel top 1155 mounting Verkocht 5
Luculenus [VERKOCHT] Apogee HD met LGA2011 mounting kit. Verkocht 16
Sw333t Scythe LGA 1156 Mounting for Mugen 2 HighFlow Product Suggesties en Nieuws 5
Thierry Koolance radiator mounting screw and nut HighFlow Product Suggesties en Nieuws 5
F Mounting plate Supreme HF Intel - Nickel HighFlow Product Suggesties en Nieuws 2
B Clear Mounting Tape 3M Scotch #4010 HighFlow Product Suggesties en Nieuws 8
R [INACTIVE] Aqua computer cuplex HD s775 mounting kit Gevonden 5
l3p [VERKOCHT] EK Supreme HF Nickel/Plexi + EK-Mounting plate Supreme Chromera Verkocht 5
The_Saviour# [INACTIVE] Corsair H50 s775 mounting Gevonden 1
Duriel Lian Li Power Supply Mounting Bracket Black : PE-03(B) HighFlow Product Suggesties en Nieuws 4
Sw333t [GEZOCHT] Corsair H50 met Socket 775 mounting erbij Gevonden 3
B Xigmatek AMD Vertical mounting kit HighFlow Product Suggesties en Nieuws 11
coolfris HEATKILLER® CPU Rev3.0 775 Mounting Kit HighFlow Product Suggesties en Nieuws 1
J Mounting voor Black Ice SR-1 560 Waterkoeling 13
V *NEW* Koolance D5 Pump Top/Mounting kit HighFlow Product Suggesties en Nieuws 3
M Apogee GTZ s1156 mounting HighFlow Product Suggesties en Nieuws 2
Source SSD Mounting van (UN)Designs HighFlow Product Suggesties en Nieuws 14
Quadcore CPU Block/Blok Mounting kits HighFlow Product Suggesties en Nieuws 5
R d-tek mounting HighFlow Product Suggesties en Nieuws 1
Traxtorm Radiator Mounting Bracket met Quick-Release HighFlow Product Suggesties en Nieuws 3
ChrisdeW D-tek fusion v1/v2 mounting 1366 input nodig Waterkoeling 10
A mounting screws thermochill PA Waterkoeling 7
A XSPC X2O Delta Intel i7 Only Mounting Plate Waterkoeling 3
M EK Supreme Mounting Plate voor i7 - 1366 HighFlow Product Suggesties en Nieuws 3
HighFlow HighFlow Black Friday 2024 is gestart HighFlow Computer Cooling Shop 3
SeaShark Mogelijk SK-UNI 120D Distroplate D-RGB - Black Edition te kopen? HighFlow Product Suggesties en Nieuws 2
HighFlow Black Friday 2023 Extra Black Friday Deals! HighFlow Computer Cooling Shop 0
