=> CPU Feature
*Set VR current limit max : DISABLED
*Thermal managment control : DISABLED
*EIST function : DISABLED
*CxE function : DISABLED
*Execute disable bit : DISABLED
*Virtualization technology : ENABLED
*Intel HT technology : ENABLED
*Active processor cores : ALL
=> DRAM Timing op auto zetten
*Channel interleave setting: Auto
*Rank interleave setting: Auto
*Memory LowGap : 1536M
*DRAM command rate : Auto
*CAS latency time (tCL) : Auto
*RAS# to CAS# delay (tRCD): Auto
*Precharge dealy (tRP) : Auto
*RAS# precharge (tRAS) : Auto
*REF to ACT delay (tRFC) : Auto
*write to PRE delay (tWR) : Auto
*Rank write to read (tWTR) : Auto
*ACT to ACT delay (tRRD): Auto
*Row cycle time (tRC) : Auto
*Read CAS# precharge (tRTP): Auto
*Four ACT WIN time (tFAW): Auto
=> Voltage Setting
*O.C Shut down Free: Enable O.C.S.D.F
*CPU VID Control: Auto
*CPU VID Special Add Limit : Enabled
*CPU VID Special Add : Auto
*Vcore Droop Control : DISABLED
*DRAM Bus Voltage : 1.650V
*DRAM PWM Switch Frequency : Nominal Frequency
*DRAM PWM Phase Control : 2 Phase operation geen andere optie hier? en welke?
*CPU VTT Special Add : Auto
*CPU VTT Voltage: auto
*VTT PWM Switch Frequency: Nominal Frequency
*VTT PWM Phase Control : 2 phase operation geen andere optie hier? zoals Full Phase ?
*CPU PLL Voltage: Auto
*IOH/ICH 1.1V Voltage : Auto
*IOH Analog Voltage : Auto
*ICH 1.5 Voltage : Auto
*ICH 1.05V Voltage : Auto
*DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
*DIMM 3/4 DQ/DQSTR Bus VREF: -00.0%
*DIMM 5/6 DQ/DQSTR Bus VREF: -00.0%
*ADDR/CMD VREF Control : Disable
*DIMM 1/2 ADDR/CMD Bus VREF: 110 deze heb je volgens mij ook veranderd niet?
*DIMM 5/6 ADDR/CMD Bus VREF: 110 want deze zijn normaal 67 dacht k?
*CPU QPI Drive Strength : Normal
*IOH QPI Drive Strength : Normal
*CPU Core Voltage : 1.35V
*DRAM Bus Voltage : 1.65V
*IOH Core Voltage : auto
*CPU VTT Voltage : auto
=> Exit Setup Shut down : Mode2
=> O.C Fail Retry Counter: Disabled
=> O.C Fail CMOS Reload: Enabled
=> PPM Function : Enabled
=> Turbo Mode Function : Enabled
* x 1 core Max Turbo Ratio : 21 X
* x 2 core Max Turbo Ratio: 20 X
* x 3 core Max Turbo Ratio : 20 X
* x 4 core Max Turbo Ratio : 20 X
CPU Non-Turbo Clock Ratio : 20 X
=> BCLK/UCLK/QPI Controller Settings
*QPI Control Settings : Enabled
*QPI Link Fast Mode : Enabled
*QPI Frequency : Auto rond de 5Gb houden
*CPU Base Clock (BCLK): 170 MHz
*Boot Up CPU Base Clock : Auto deze heb k nooit geprobeerd
*PCIE Clock : 100 MHz
*DRAM Frequency : Auto Je geheugen snelheid instellen volgens specs
*UnCore Frequency : Auto hiervan afblijven, altijd auto zetten
*CPU Spread Spectrum: Disabled zeer goed, disabled verbeterd stabiliteit
*PCIE Spread Spectrum : Disabled
Voila, dit zijn ze denk ik.
Groetjes
