Gigabyte HD5870 1Gb Super Overclock
Colossus
[HF]
Gigabyte extends their Super Overclock series with a card that is sure to blow your socks clean off.
image3.php
When it comes to pre-overclocked graphics cards, Gigabyte isn’t usually the first manufacturer that jumps to mind but they have been working hard to bring some excitement to enthusiasts. ASUS has their TOP, Matrix and Ultimate series and MSI had their Lightning products but at the time it seemed like Gigabyte was the odd man out of a very lucrative market. They answered back in a big way with the Super Overclock Series.
Unfortunately, past attempts at releasing Super Overclock cards proved to be a bit difficult since the GTX 260 SOC and GTX 275 SOC came out very late in the GT-200 series life cycle. Nonetheless, both of these cards blew us away with their performance and incredible overclocking potential. Gigabyte is now working hard on releasing Super Overclocked versions of the HD 5870 and HD 5850 1GB cards.
The HD 5870 SOC was first shown at CES but was not widely covered by the media. However, we now have some additional details for you about this soon to be highly anticipated card including some interesting component choices and a picture of the finalized design.
The card itself should retain a near-reference PCB size but that is where the similarities between standard, vanilla HD 5870 cards stops. Gigabyte has gone all out here with a massive dual slot cooler which incorporates a large-size aluminum fin / copper heatpipe construction along with a pair of fans to keep heat under control. Unfortunately, this design means most of the heat produced by the core will stay within the general vicinity of the card but with good case airflow, this shouldn’t cause an issue.
SOC 3 Gigabyte Shows HD 5870 1GB Super OverclockAccording to Gigabyte, all of the GPU cores and GDDR5 memory destined for this card will be strictly sorted in accordance with their “GPU Gauntlet” process. This means only the highest overclocking units will be installed onto the SOC series of cards which should also allow for better power consumption and slightly lower heat at stock speeds.
Much like ASUS’ addition of a SuperML cap to their higher-clocking models, Gigabyte has decided to use NEC’s new Prodilizer capacitors to their design. These digital capacitors will supposedly help this card’s core speed push past the 1Ghz barrier by providing high current capacity and a quick switching frequency. It is also important to remember that the Prodilizer caps will be used to supplement Gigabyte’s Ultra Durable VGA design which incorporates two ounces of copper into the PCB along with other tweaks to improve efficiency and product life.
SOC 5 Gigabyte Shows HD 5870 1GB Super OverclockTo additionally help overclockers, there will be voltage read points incorporated directly onto the card’s PCB and Gigabyte will also be launching a revamped software tuning utility. While it may look like a confusing layout the new Ultra Durable VGA software allows for core, shader (on upcoming NVIDIA cards) and memory clocking, GPU and memory voltage tweaking, PWM adjustments and finally fan speed settings as well.
Unfortunately, the final clock speeds of this card are still up in the air but considering the specifications of some other overclocked HD 5870 cards being released in the next month, we expect SOC’s core to run in excess of 1Ghz with the memory running at ~5Gbps. To make matters even more interesting, it seems like this card in particular will be hitting store shelves shortly before the release of NVIDIA’s GTX 480 and GTX 470 cards. This could make for some interesting competition.
Bron: Gigabyte Shows HD 5870 1GB Super Overclock | Hardware Canucks
S Gigabyte Gaming OC Waterforce Advies Waterkoeling Setup 2
I Gigabyte 3D Mercury Splitter Valve Waterkoeling 7
K Waterblok voor Gigabyte Aorus 2070 super HighFlow Product Suggesties en Nieuws 5
K [Waterkoeling] ~€1000 euro, i9-9900K, Gigabyte Xtreme Waterforce 5G, 2080Ti Waterfor Advies Waterkoeling Setup 5
R Crossfire ?? Gigabyte Radeon R9 380, 4GB Hardware & Software 2
S [GEZOCHT] Gigabyte MIB T5140 behuizing Gevonden 1
Tath "New" Bitspower Nickel Plated (Clear) voor de Gigabyte GA-X99-Gaming G1 WIFI HighFlow Product Suggesties en Nieuws 0
Tath Bitspower Nickel Plated Full-Covered-Block Black and Clear for Gigabyte GA-X99-Gaming HighFlow Product Suggesties en Nieuws 0
D Zoekt waterblock voor Gigabyte GTX 780 windforce Waterkoeling 1
R Blauwe verf voor de Gigabyte Z87X UD4H Cases en Modding 18
Viepert [VERKOCHT] Gigabyte GA-Z77X-UD5H Verkocht 3
J Gigabyte 5770 silent cell gaan waterkoelen om hem dunner te maken Waterkoeling 3
P [VERKOCHT] GigaByte HD5570 OC Verkocht 1
vincent [CANCELLED] Gigabyte G1 killer, I7 960, adata en veel meer Verkocht 10
Luculenus [CANCELLED] Q6600+P5Q deluxe+8 gig kingston DDR2+ 2X HD6870OC Gigabyte 3F Verkocht 9
M [VERKOCHT] Gigabyte GTX 460 OC2 SLI Verkocht 2
animal baars [IN-ACTIVE] Gigabyte X58A-UD7 waterblock Gevonden 0
R [VERKOCHT] Gigabyte GA-P67A-UD5-B3 Verkocht 1
B Nooit meer Gigabyte voor mij. Hardware & Software 5
S Gigabyte GV-N550OC-1GI GTX550 Ti 1GB Waterblok Waterkoeling 1
B Waterkoeling CPU + 2x gigabyte gtx 560 ti Advies Waterkoeling Setup 3
B waterkoeling gigabyte GTX 470 soc (GV-N470SO-13I) Advies Waterkoeling Setup 3
M [WC-Advies] Gigabyte GA-P55-UD4, I5-750, Gigabyte GTX 460 SLI €400 Advies Waterkoeling Setup 7
D [VERKOCHT] Gigabyte X58A-UD3R Verkocht 6
C [Waterkoeling] €1200, intel core i7 920 @ 3.8GHz, GTX 580 SLI, Gigabyte EX58-UD3R Advies Waterkoeling Setup 13
C Gigabyte GA-H55N-USB3 HighFlow Product Suggesties en Nieuws 6
Thierry Gigabyte GA-Z68X-UD7-B3 HighFlow Product Suggesties en Nieuws 5
T Gigabyte P55-UD6 waterblokken HighFlow Product Suggesties en Nieuws 4
D Gigabyte X58A-UD3R Gesloten 1
N [waterkoeling] €500-€700 I7920, 5870,GIGABYTE -EX58-UD5 Advies Waterkoeling Setup 11
T Hulp met overclocken Intel E8500 + Gigabyte EP45-DS3 Overclocking 7
animal baars Hulp OC i7-930 D0 + Gigabyte X58A-UD7 Overclocking 10
Bullus [VERKOCHT] Gigabyte GA-X58A-UD7 V2 Verkocht 5
S waterkoeling gigabyte x58a-ud3r NB & SB????? Waterkoeling 2
P Gigabyte GTX470 Super Overclock Advies Waterkoeling Setup 3
D [INACTIVE] Gigabyte GA-M59SLI-S5 (of een soort gelijke bord) Gevonden 4
Oli4v [VERKOCHT] Gigabyte P35, DDR2 Verkocht 9
Wouzke GIGABYTE EX58-UD4P Overclocken Overclocking 23
Fedmas Gigabyte UD6 (Defect) Verkocht 4
The_Saviour# [INACTIVE] Gigabyte GA-X38 mobo blockjes Gevonden 0
D [WC] 750 euro, i7 930, Gigabyte GA-X58A-UD7 NB, 1x HD4870X2 Advies Waterkoeling Setup 5
