Nieuwe EVGA mobo's
Hayato
Banchetto 101 Triple SLI
EVGA nieuws :
Following last week's release of EVGA X58 FTW3, the company is ready with two new boards, the EVGA X58 SLI3 and X58 Classified3. While being based on essentially the same board design as the X58 SLI LE and X58 Classified, these boards have feature updates which include USB 3.0, and SATA 6 Gb/s. Both these features use 3rd party controllers from NEC and Marvell, and are available in 2-port forms.
For existing users of X58 SLI LE and X58 Classified, EVGA developed its own 2-port USB 3.0 addon card.
Ben erg benieuwd naar deze plankjes .........
Iemand met nog meer info ?
Quadcore nieuwe EVGA x58 1366 Hardware & Software 4
W Nieuwe setup Waterkoeling 1
