Mayhems Biocide Extreme 10ml
k.3nny
Oldscool.
LINK SITE/PRODUCT:
Mayhems Biocide Extreme is the Ultimate Steriliser for performance water cooling systems. It prevents contamination in the water cooling system, acts as a PH balancer and finally a but not least a de-scale property in order to combat scaling issues. Suitable for use in liquid cooled computers that contain Mayhems dye range.
Benefits of Mayhems Biocide Extreme
1. Mayhems Biocide Extreme Kills Green water, Blue-Green algae, slime, scum, mould spores and all types of Green algae on contact.
2. Suitable for use in water that has been dyed. Will not Foul the consumers system.
3. Highly effective in preventing the build up of bio-films in PC water cooling.
4. Mayhems Biocide Extreme gives a 99.9% reduction of the species listed below within three hours.
5. Legionella pneumophila (Legionnaires Disease), Pseudomonas aeruginosa, Staphylococcus, Micrococcus luteus, Streptococcus agalactiae, Escherichia coli.
6. Fast acting and effective at low concentration.
7. Non-foaming.
8. Liquid easy to dispense.
9. Functional over a broad temperature range.
10. De-scaling
11. PH balancer
12. Free PH Test Kit
Usage
Test liquids with Mayhems Ph Test kit
Add 1 drop of biocide and re-test with the PH test Kit. Keep the PH Level between Ph 6.5 / 8.5.
Add a second drop if necessary.
Check the water every 2 to 3 months to make sure the biocide is still working and top up and re test as necessary
DO NOT MIX WITH MAYHEMS PRE-MIXED FlUIDS OR COOLANTS.
DO NOT CONSUME CONTAINS COPPER SULPHATE, CITRIC ACID AND DYES
Graag zie ik dit in de shop verschijnen :)
P Mayhems biocide(extreme) HighFlow Product Suggesties en Nieuws 1
L Mayhems Pastel Pink HighFlow Product Suggesties en Nieuws 2
Jason Mayhems XTR Nano Tech Premixed Coolant 1 Litre - White HighFlow Product Suggesties en Nieuws 0
Jason Mayhems X1 UV Green Coolant 1L MD-X1-UVG HighFlow Product Suggesties en Nieuws 0
Jason Mayhems Restock (incl. Mayhems XTR Nano Tech) HighFlow Product Suggesties en Nieuws 0
A Mayhems Blitz One Shot Waterkoeling 2
R Mayhems Blitz Part 2 Waterkoeling 4
R Mayhems Aurora 2 Silver voor lang gebruik? (1 jaar) Waterkoeling 1
Besje Mayhems dye UV pink HighFlow Product Suggesties en Nieuws 3
the_cyberspace Mayhems X1 UV Red Coolant 1Ltr HighFlow Product Suggesties en Nieuws 4
PlayGamble Mayhems Pastel RED HighFlow Product Suggesties en Nieuws 4
P Mayhems Dye Purple HighFlow Product Suggesties en Nieuws 1
Zwelgje Mayhems Pastel Sunset Yellow HighFlow Product Suggesties en Nieuws 5
T Demi water met Mayhems Dye en nog iets nodig? Waterkoeling 2
G Mayhems X1 UV Blue Coolant HighFlow Product Suggesties en Nieuws 3
arwin74 Mayhems X1 UV Deep Purple Coolant HighFlow Product Suggesties en Nieuws 1
corecrusher vraag tbv Mayhems Aurora pearls Advies Waterkoeling Setup 20
wâldpyk Mayhems Aurora en White coolant Waterkoeling 52
Jason EK-Quantum Momentum² ROG Crosshair VIII Extreme D-RGB - Plexi HighFlow Product Suggesties en Nieuws 1
Jason Thermal Grizzly Kryonaut Extreme - 2G HighFlow Product Suggesties en Nieuws 0
M Triple loop extreme overkill Gallery & Build Logs 9
R Waterkoeling Maximus IX Extreme Advies Waterkoeling Setup 1
A Asus Rampage II Extreme Waterkoeling. Waterkoeling 3
Willius Kingpin Extreme Cooling Dragon F1 HighFlow Product Suggesties en Nieuws 7
C internet snelheid op asus rampage2 extreme Problemen & Oplossingen 12
volcom GELID Solutions GC Extreme Thermal Compound 3.5g HighFlow Product Suggesties en Nieuws 3
Tath Bitspower blokken voor de Asus Rampage 5 Extreme Moederbord HighFlow Product Suggesties en Nieuws 5
Freddy Extreme korting op waterblokken voor oudere hardware! HighFlow Computer Cooling Shop 0
Traxtorm ASUS Rampage III Extreme onderdelen Verkocht 0
D [CLOSED]asus rampage 3 extreme + waterblok +org. koelblok + i7-930 +12gb vengeance Gesloten 2
Vannos [VERKOCHT] Asus Rampage II Extreme + WC blocks ( cpu-nb-sb) Verkocht 1
l3p [VERKOCHT] ASUS Rampage IV Extreme Verkocht 1
J EK koelblok Asus Rampage extreme III op een Asus Rampage extreme III black edition Advies Waterkoeling Setup 5
F [IN-ACTIVE] Bitspower D5 / MCP655 Dual Mod Top/Extreme Verkocht 0
Aequitis [VERKOCHT] Asus Maximus Extreme IV 3.0 incl Fullcover Waterblock Verkocht 1
Hightower waterblokken voor de asrock extreme 9 x79? Waterkoeling 0
