Bitspower blokken voor de Asus Rampage 5 Extreme Moederbord
Tath
Well-known member
===== update 12-11-14 =====
Op voorraad!
Bitspower AIX99R5E Nickel Plated Full-Covered-Block (Black) - BP-WBAIX99R5EFCBAC-BK
Bitspower AIX99R5E Nickel Plated Full-Covered-Block (Clear) - BP-WBAIX99R5EFCBAC-CL
BP-WBAIX99R5EFCBAC-BK Bitspower AIX99R5E Nickel Plated Full-Covered-Block (Black)
Ik miste nog een foto
Features:
1. Design For ASUS RAMPAGE V EXTREME.
2. Included CPU/ChipSet and MOS Blocks.
3. Full-Covered-Block Design.
4. Block TOP Cover Made Of Hi-Quality Black Acrylic.
5. Block Base Made Of Hi-Quality Copper.
6. Block Base High Durability Nickel Finished In Shining Silver.
7. Polished Stainless Panel In Matt Black.
8. RoHS Compliant.
Dimension ( LxWxH ) : 270.8x212x48.7mm
Thread : G1/4" x 2
Included :
1. AIX99R5E Full-Covered Armor (Black) x 1 PCS.
2. BP-MBWP-C90 x 6 PCS.
3. AIX99R5E Nickel Plated (Clear) x 1 Set.
4. CPU Block Summit EF (Intel) (Acrylic Top Version) x1 Set.
5. Backup O-Ring x 1Set.
6. Thermal PAD Included.
7. Mounting Screws/Accessories.
Op voorraad!
Tath
Well-known member
Bitspower Nickel Plated Full-Covered-Block (Red) voor de Asus Rampage 5 Extreme
BP-WBAIX99R5EFCBAC-RD Bitspower AIX99R5E Nickel Plated Full-Covered-Block (Red)
Features:
4. Block TOP Cover Made Of Hi-Quality ICE Red Acrylic.
8. RoHS Compliant.
Thread : G1/4" x 2
Included :
1. AIX99R5E Full-Covered Armor (Red) x 1 PCS.
***All Specification Will Be Changed Without Further Notice***
Tath
Well-known member
Bitspower blokken voorde Asus Rampage 5 Extreme (chipset & mos) Clear "Black Panel"
BP-WBAIX99R5ENPAC-CL Bitspower AIX99R5E Nickel Plated (Clear)
Features:
2. Included ChipSet and MOS Blocks.
3. Real Full Water-Cooled Solution.
4. Block TOP Cover Made Of Hi-Quality Acrylic.
8. RoHS Compliant.
Dimension N+S ( LxWxH ) : 212x161x26MM
Dimension MOS ( LxWxH ) : 104.7x23.5x26MM
Thread : G1/4" x 2
Included :
1. Backup O-Ring x 1Set.
2. Thermal PAD Included.
3. Mounting Screws/Accessories.
http://www.bitspower.com/html/product/pro_show.aspx?num=81093405&kind2=124
Tath Bitspower Blokken voor de GTX 980 "Nice color led in it" HighFlow Product Suggesties en Nieuws 4
Freddy Enkele nieuwe Bitspower: Nieuwe D5/MCP655 topjes, GTX470 en GTX480 blokken HighFlow Product Suggesties en Nieuws 3
Bl4ckj4ck666 Bitspower waterblock nvidia rtx3090fe Waterkoeling 1
Jason Bitspower BIG SALE% ­čĆĚ´ŞĆ HighFlow Product Suggesties en Nieuws 0
G FS: Bitspower, EKWB, Koolance en Barrow Fittingen en koppelingen Koeling 1
