HighFlow OC team topic
sanders kan je je screen hier posten?? :)
zoizo wel weer nice 10 puntjes ;)
Vooruit dan maar :)
zoizo al nice
probeer de volgende keer je geheugen sneller te krijgen en ook je NB freq wat omhoog ;)
je kan het doen door je cpu multi naar 20 te zetten en je fsb naar de 230 of de multipliers aanpassen (je moet redelijk makkelijk een hogere score kunnen krijgen ;) )
Eigenlijk alleen dit; datum :D 10-06-2009
A lot of users is complaining about overclocking limitation of MSI 5870 in Afterburner, which is because of CCC limit by BIOS. So we will make a special unlock bios for 5870, you can flash into any reference 5870 card you want.
New overclock limit is core/mem = 1800/2600 MHz.
maar met de nieuwe afterburner kan men ook via de config instellen volgens mij.
Afterburner 2.0.0 Final + Kombustor 1.1.3 - Guru3D.com Forums
[Changelog]
- Voltage control layer has been seriously revamped to give additional freedom
to extreme overclockers with new custom design MSI graphics cards. Now MSI Afterburner is able to control up to 3 voltages on custom design MSI Fermi and other future custom design MSI graphics cards. New adjustable voltages include memory voltage and special multi-purpose auxiliary voltage feeding either memory bus (also known as VDDCI on AMD graphics cards) or PCIE bus and crystal (PEXVDD on NVIDIA graphics cards)
- Added core, memory and auxiliary PEXVDD voltage control for custom design MSI N480GTX Lighning series graphics cards with uP6225+uP6262 voltage regulators
- Added core, memory and auxiliary PEXVDD voltage control for custom design MSI N470GTX Twin Frozr II OV3 series graphics cards with uP6218+uP6262 voltage regulators
- Added core, memory and auxiliary PEXVDD voltage control for custom design MSI N460GTX Hawk series graphics cards with uP6262 voltage regulators
- Added core voltage control for custom design MSI N460GTX Cyclone series graphics cards
- Added auxiliary VDDCI voltage control for reference design AMD RADEON HD 5870 series graphics cards
- Added fan tachometer monitoring for NVIDIA graphics cards. Please take a note that not all graphics cards are tachometer reading capable. So depending on graphics card and cooling system fan tachometer monitoring can be unavailable
- Optimized NVIDIA driver-level clock frequency monitoring codepath
- Minimum clock limits for all graphics cards have been reduced from 75% to 50%
- Dynamic overclocking, voltage and fan speed limits. MSI Afterburner no longer uses static slider limits calibration and adjusts the limits dynamically when some external factors affect it (e.g. Overdrive clock limits on AMD cards or VGA BIOS fan speed and voltage limits on NVIDIA GeForce GTX 400 cards)
- New temperature hysteresis settings for software automatic fan control mode gives you additional way to improve cooling system thermal and acoustic parameters
- Now fan speed limits (i.e. minimum and maximum fan speeds accepted by VGA BIOS and display driver) are displayed in custom fan speed curve editor
window
- Built-in skin sizes have been reduced due to optimized internal skin panels representation and optimized compiled bitmap cache
- Optional skin compression ability in the built-in skin compiler. Skin format reference documentation has been updated to document new compression options
- Minor built-in skins appearance tweaks
- Now MSI Afterburner uses previously undocumented power user oriented startup mode via the task scheduler under Windows Vista / Windows 7. MSI Afterburner launch no longer requires UAC confirmation at Windows startup. Please take a note that Microsoft Visual C++ 2008 runtime libraries must be installed to get new startup mode working
- Now MSI Afterburner automatically fixes startup link if <Start with Windows> or <Apply overclocking at system startup> is enabled but the registry or task scheduler startup entry is missing
- Startup profile is now displayed in <Apply at Windows startup> option floating tooltip instead of the main window
- Now power users can enable optional DirectInput based hotkeys handler via the configuration file. DirectInput based hotkeys processing can seriously reduces hotkey response time in the applications heavily loading CPU (mostly 3D games) and leaving not enough time for processing standard keyboard input message queues. Please take a note that enabling such sophisticated hotkeys handling mode can cause some system security applications (e.g. pro-active application behavior analysis module of KIS) to warn you about possible keylogging threat
- Improved skin engine, now skinned controls support horizontal and/or vertical centering. Skin format reference guide has been updated to document these new alignment modes
- MSI On-Screen Display server has been upgraded to version 3.7.2. New version gives you the following improvements:
- Now screen capture events are identified visually by text message flashing in On-Screen Display during 0.25s
- Built-in skin sizes have been reduced due to optimized compiled bitmap cache
- Added On-Screen Display profile for Startcraft II : Wings of Liberty
- Added configuration file switch allowing sending MSI Afterburner to system tray instead of closing on <Close> button click
- <Start the task only when computer is running on AC power> option is no longer set in the startup task settings to allow automatically starting application via the task scheduler on laptops or on some UPS models
- Added optional data filtering mode for all hardware monitoring graphs. Now it is possible to enable special math data filtering algorithm independently for each hardware monitoring graph to reject misreading spikes caused by sensor access conflicts when running multiple hardware monitoring tools at the same time
- Now it is posssible to use both core and shader clock as the primary clock when adjust the clocks in linked mode
- Fixed videomemory usage monitoring for non-primary NVIDIA graphics cards
- Application restart is no longer required to apply new user interface language
- Updated localization engine. Now floating tooltips based context help system supports macro definitions
- Localization reference guide documentation has been updated to v1.1
- Various typo fixes in different language packs
- Added Korean localization
Is het misschien een idee om samen met de HF-leden, bepaalde hardware samen te kopen bij Freddy en deze dan om de beurt kunnen gebruiken (onder de betaalde leden). Zoals gpu's/ cpu's /mems..)
Zo kan men de punten flink wat opkrikken op hwbot en bepaalde dure hardware (i7 980x) toch goedkoper kunnen gebruiken.
Over hoe en wat precies (regels enz.) moet dan nog overlegd worden.
lees ook even de hardware sharing regels door van Hwbot.. ;)
Als freddy de rechtmatige eigenaar is mag hij de 2d score's uploaden en niemand anders..
voor 3d mag die shared worden.. alleen de gpu's weer niet daarvan mag de rechtmatige eigenaar alleen uploaden..
Dus is gewoon vals spelen jongens als jullie alles gaan sharen..:evil:
Als jullie dat leuk vinden moeten jullie dat gewoon doen.. Komen ze snel genoeg achter..
Chip heeft een max en die zal bij jullie allemaal gelijk liggen zo'n beetje...Dan komen er al snel twijfels
K Team Thermaltake VS Team HIGHFLOW! VOD Gaming 1
Freddy Team HighFlow wishes you a Merry Christmas and a Happy New Year 2012! HighFlow Computer Cooling Shop 7
Freddy Team HighFlow wishes you a Merry Christmas and a Happy New Year! HighFlow Computer Cooling Shop 19
Freddy HighFlow OC Team + moderator OC subforum Overclocking 65
Wouter De HighFlow Forum Team lijst HighFlow Computer Cooling Shop 2
damunk HighFlow WCG Folding Team Hardware & Software 47
Johnny [Team HighFlow] GTA IV? [PC] Gaming 35
HighFlow HighFlow Black Friday 2025 HighFlow Computer Cooling Shop 0
HighFlow HighFlow Black Friday 2024 is gestart HighFlow Computer Cooling Shop 3
Freddy HighFlow Veilingen! HighFlow Computer Cooling Shop 2
J Hoi Highflow en PC enthousiasten Introductie: Stel jezelf en jouw PC voor 2
R HighFlow: Customer Review HighFlow Testimonials / Shopreviews 1
M Super klantenservice. Bedankt HighFlow HighFlow Testimonials / Shopreviews 1
C Highflow nl web shop (Germany delivery question) HighFlow Webshop 4
Freddy HighFlow Black Friday 2019 HighFlow Computer Cooling Shop 4
Freddy HighFlow Forum V3 online! HighFlow Computer Cooling Shop 4
A HighFlow HighFlow Testimonials / Shopreviews 0
Freddy HighFlow partner programma HighFlow Computer Cooling Shop 9
Freddy Fijne feestdagen en beste wensen 2018!!! Let op, gewijzigde openingstijden HighFlow HighFlow Computer Cooling Shop 7
Freddy HighFlow Black Friday 2018 HighFlow Computer Cooling Shop 1
Freddy HighFlow VH1 Adjustable Aluminum GPU/VGA Support Strut/Holder Anti-Sag HighFlow Product Suggesties en Nieuws 0
Freddy Thermaltake @ HighFlow, 10% introductiekorting tot aanstaande zondag! HighFlow Computer Cooling Shop 0
Freddy Fijne feestdagen 2017!!! Let op, gewijzigde openingstijden HighFlow HighFlow Computer Cooling Shop 5
ForresT Highflow Polo's en andere kledingstukken Lan Party 23
Freddy HighFlow op vakantie: Vrijdag 10 november t/m vrijdag 24 november 2017 HighFlow Computer Cooling Shop 3
Freddy Trezor Hardware Wallet (Bitcoin & Altcoin) Order @ HighFlow HighFlow Product Suggesties en Nieuws 1
Freddy The Party 15: HighFlow Casemod Compo, doe nu mee! Lan Party 20
