MB - Asus Rampage 2 Extreme
CPU -
RAM -
CPU Cooler -
Fan -
VGA -
PSU -
HDD -
AI overclock - manual or auto
OC from CPU level up - auto or i920/i940/i965
OC from Memory level up - auto or manual
CPU Ratio setting - auto or XX
CPU configuration
CPU Ratio Setting - auto
C1E Support - disable or enable
Hardware prefetcher - enable or disable
Adjacent Cache line prefetcher - enable or disable
Intel Virtualization tech - disabled or enable
CPU TM Function - enable or disable
Execute Disabled bit - disabled or enable
Intel HT Technology - enable or disable
Active Processor Cores - all or 1 or 2
A20M - disabled or enable
Intel Speedstep tech - enable or disable
Intel Turbo Mode tech - enable (Not shown if Speedstep is disabled)
Intel C-STATE tech - disabled or enabled
BCLK frequency - XXX
PCIE frequency - XXX
DRAM frequency - DDR3 XXXXMHz
UCLK frequency - XXXXMHz
QPI frequency - auto or Manuel Value
Dram timing control
1st iformation - Insert Timings Here in X-X-X-XX -X-X-Xformat
2nd information - Insert Timings Here in X-X-X-XX -X-X-Xformat
3rd information - Insert Timings Here in X-X-X-XX-X-X-X format
EPU II phase control - full phase
Load-line calibration - enable or disable
CPU differential amplitude - auto or manuel values
Extreme OV - disabled or enable
Current voltage 1.54v - 1.812v - 1.35v (May be different)
Cpu voltage - X.xxx v or auto
CPU PLL voltage - X.xxxx v or auto
QPI-Dram voltage - X.xxx v or auto
Current voltage 1.131v - 1.508v - 1.111v - 1.508v
IOH voltage - auto
IOH PCIE voltage - auto
ICH voltage- auto
ICH PCIE voltage - auto
Current voltage X.xxx v, X.xxx v, X.xxx v ,X.xxx v
DRAM Bus voltage - X.xxxx v or auto
DRAM REF voltage - auto
Debug mode - string
Keyboard TeakIt comtrol - disabled or enable
CPU spread spectrum - disabled or enable
PCIE spectrum - disabled or enable
CPU clock skew - auto or XXXX ps
IOH clock skew - auto or XXXX ps
