- Naam product
Liquid Evolution Customizable Full Tower Case
- Naam fabrikant
FrozenQ
- Omschrijving product
- Supports up to 1 triple 120mm radiator and 1 quad 120mm radiator
- Integrated shelf separates components for a cleaner look
- Integrated shelf comes pre-made with 4 pass through holes for routing tubing or cables
- Designed for an optimal single loop configuration as shown in picture below
- 3/4" spacing behind motherboard tray with access to bottom compartment for easy, concealed cable management
- 120mm fan cooled hard drive rack capable of holding 4 hard drives
- 4 5.25" drive bays, ideal for the average user
- Supports ATX, mATX, and EATX motherboards
- Designed with a specific place to mount up to a 250mm cylinder reservoir, perfect for showing off your Liquid Fusion reservoir
- Grill design on motherboard tray keeps air moving behind the board and results in cooler temperatures
- Large minimalistic window
- Optional aluminum trim comes in dozens of colors, perfect for personalizing your case to suit your theme
- Dimensions: 22"x21"x8" (559mm x 533mm x 203mm)
- Link/URL naar website van de fabrikant + pagina van het product
FrozenQ Liquid Evolution
- Link/URL naar Reviews van het product
Geen, is nog niet verkrijgbaar..
- Adviesprijs en eventueel een link naar het productpagina bij andere shops.
"The final case is going to $274.99 available in 2 styles. We will also be offering a complete "Build Your Own" Liquid Evolution option for $374.99. With this, you'll be able to choose how many fan holes, what style fan grills, custom interior and exterior color, window style and much more. You can even have your own designs cut or etched into it. It will include up to $60(1 hour on the laser) worth of free etching."
- Foto's van het product
- Overige informatie
Ik heb hier indirect wel interesse in, als hij uitkomt. En ben heel erg benieuwd tegen welke prijzen hij daadwerkelijk beschikbaar komt, als hij al beschikbaar komt binnen afzienbare tijd.... Het ziet er IMO ontzettend goed uit!
Dus, kan iemand evt. contact zoeken met de eigenaar/maker/bedrijf voor wat meer info?
- Naam fabrikant
FrozenQ
