WiSK
Naam product
Coollaboratory Liquid Copper
Link
Coollaboratory Liqud Copper - Heat conduction paste with high-purity copper for optimal results on all contact surfaces.
Foto
Tekst
Link
Foto
Tekst
Coollaboratory Liquid Copper – our answer to a conventional paste on base of silicone!
The Coollaboratory Liquid Copper is a high-end- heat conduction paste for the usage on all materials. The heat conduction paste consists of a complex matrix of silicone with quality like in industry applications and also high-purity micro-copper particles (99,9%).
The used matrix of silicone is high resistant towards temperatures over 800 Grad Celsius and is with this property better than similar heat conduction pastes where performance and durability is concerned. Through its texture the new Coollaboratory Liquid Copper can be applied very easy on the contact surfaces of the heat sources and also on coolers and is even usable without problems for uneven surfaces and cooler with Direct-Touch-Technology.
The Coollaboratory Liquid Copper offers an outstanding performance compared to many other heat conduction pastes on base of silicone and can score with its easy application not only with pros, but just with beginner.
