Indigo liquid metal
MrGiorgio
De Planner
Ik zag bij cyberdruid deze koelpasta.
What is Indigo Xtreme™
Indigo Xtreme™ is an Engineered Thermal Interface (ETI) that fits neatly between a CPU lid and heat sink (or waterblock) to keep CPUs cooler. Unlike greases, metallic thermal interface pads or liquid metal alloys, Indigo Xtreme™ is a self-contained and sealed structure, deploying a Phase Change Metallic Alloy (PCMA) which reflows and fills surface asperities on the CPU lid and heat sink. The resultant interfacial layer is void-free and robust, with low thermal contact and bulk resistance.
How Indigo Xtreme™ Works
The overall thermal performance of a thermal interface is the sum of the bulk thermal resistance (which is the inverse of bulk thermal conductance) of the material and its two surface contact resistances (on both the CPU lid and heat sink). Greases have good surface wetting properties and therefore they exhibit low contact resistance; however, they have high bulk thermal resistances. Metallic pads possess low bulk thermal resistances, but surface oxidation limits their surface wetting ability, resulting in higher contact resistance.
Indigo Xtreme™ achieves high thermal performance through the optimized deployment of molten, oxide-free PCMA, thereby yielding low contact resistance and low bulk resistance.
At the heart of the one-of-a-kind Indigo Xtreme™ ETI is a proven PCMA deployment structure. When heated (see Installation Guide), the sealed deployment structure directs flowing PCMA into CPU lid and heat sink micro-surface asperities while flushing out entrapped air. The asperity filling PCMA creates a corrosion-resistant hermetic (airtight) seal between the lid and heat sink, resulting in long-term reliability.
How to Use Indigo Xtreme™
The Indigo Xtreme™ ETI is offered as part of an Engineered Thermal Interface Kit. This kit includes several cleanroom-grade surface cleaning products to ensure the highest quality deployment possible. Once the CPU lid and heat sink surfaces have been prepared, the ETI is aligned to the lid and held in place with its own adhesive layer. Following the bolting of the heat sink to the motherboard, the ETI may be reflowed by simply running the CPU under load as seen in the Installation Guide.
Ervoor:
Erna:
Review
Is dat misschien wat? Of hebben we dat al in de shop?
Link van de fabrikant
Vissa
Vissa!
Hm, ik heb er zelf helaas geen foto's van! Als de CPU er weer uit moet zal ik eens pics maken wat het met je CPU doet! :)
En niet alleen je CPU natuurlijk. Mijn Supreme HF is ook geen spiegel meer, dat is allemaal aangetast. Een vieze vlek wordt het! ;)
Vissa
Vissa!
Nee, dat denk ik niet. Het koelblok blijft zo glad als een spiegel, hij spiegelt alleen niet meer. Ik zie geen verschil in prestaties nadat ik het vloeibaar metaal opnieuw heb gebruikt!
Ik denk dat alle vloeibare metalen het oppervlak aantasten, dat is gewoon een bijkomend iets van dit goedje!
H TIM Prolimatech PK-1 5g of Indigo Extreme HighFlow Product Suggesties en Nieuws 4
E lappen & artic silver 5 of indigo Xtreme? Overige Koeling 8
M Indigo Xtreme Thermal Interface HighFlow Product Suggesties en Nieuws 8
M 'TIM': Indigo Extreme & Shin-etsu X23 HighFlow Product Suggesties en Nieuws 15
Bl4ckj4ck666 MSI Z97 GAMING 9 ACK LIQUID COOLED DESKTOP Hardware & Software 7
S Primochill Vue Koelvloeistof / Liquid / Coolant HighFlow Product Suggesties en Nieuws 108
Freddy Liquid.cool Koelvloeistof / Coolant / Componenten HighFlow Product Suggesties en Nieuws 1
C Info componenten custom liquid cooling set Advies Waterkoeling Setup 26
meneer peer Coollaboratory liquid Ultra 1ML HighFlow Product Suggesties en Nieuws 3
Hightower Liquid extasy waterblokken HighFlow Product Suggesties en Nieuws 41
Freddy EK-Predator is setting a new standard for AIO liquid cooling! HighFlow Product Suggesties en Nieuws 6
V Liquid SLI upgrade 1400/1500,- Budget Advies Waterkoeling Setup 26
A liquid cooling system Advies Waterkoeling Setup 1
arwin74 540 Liquid Gallery & Build Logs 51
WiSK Coollaboratory Liquid Copper HighFlow Product Suggesties en Nieuws 1
C ASUS Republic of Gamers FERRARI RED Liquid Cooled PC Introductie: Stel jezelf en jouw PC voor 7
ChillPascal FrozenQ Liquid Fusion Blue Reservoir V2 Waterkoeling 2
bundymania [Bundymania Kurzreview] Liquid Extasy Universalkühler VUCI - die günstige Alternative HighFlow Product Reviews 2
Asphiax Koolance LIQ-702 Liquid Coolant Bottle, High-Performance, 700mL (UV Red) HighFlow Product Suggesties en Nieuws 2
aadje93 Coollaboratory Liquid Ultra HighFlow Product Reviews 55
D Koolance Liquid Coolant Bottle, High-Performance, 700mL (Colorless) HighFlow Product Suggesties en Nieuws 1
Besje Liquid Extasy Rampage 3 Gene fullcover block HighFlow Product Suggesties en Nieuws 5
E Levertijd FrozenQ Liquid Fusion Blauw HighFlow Computer Cooling Shop 18
M FrozenQ Liquid Evolution HighFlow Product Suggesties en Nieuws 3
Alex EK H3O Advanced Liquid Cooling Kit HighFlow Product Suggesties en Nieuws 11
Vissa [VERKOCHT] FrozenQ Liquid Fusion Red Reservoir Verkocht 1
Vissa [VERKOCHT] FrozenQ Liquid Fusion Red 250MM Verkocht 11
J wie kan voor mij een heel nieuw liquid cooling systeem samenstellen. Advies Waterkoeling Setup 96
F FrozenQ Liquid Fusion Reservoir barst! Waterkoeling 43
O MC-CASE-EVO-W MagiCool EQ Liquid Cooling Case Window vragen Advies Waterkoeling Setup 7
Don_Holio Don's Liquid i7 Gallery & Build Logs 7
Slader Danamics LMX: Liquid cooling is back HighFlow Product Suggesties en Nieuws 6
Thierry Liquid Extasy HighFlow Product Suggesties en Nieuws 15
M Mijn eerste Liquid Cooling System Waterkoeling 8
Robin Gigabyte x58 UD5 / xtreme Liquid blocks. HighFlow Product Suggesties en Nieuws 6
Craven liquid metalpad HighFlow Product Suggesties en Nieuws 3
Oli4v WC Log: Liquid P182 Gallery & Build Logs 188
stravinski Modified TT Kandalf Liquid cooled, Stravinski & Ralpios Cases en Modding 270
N Danamics LM10 - Metal Liquid Cooling HighFlow Product Suggesties en Nieuws 71
k.3nny lancool k7 metal boned HighFlow Product Suggesties en Nieuws 11
