Dual socket I7 mobo van EVGA !!!
Nog wat meer info wat dit lekkere bord:
Vers van CES
I just came out of my meeting at the EVGA suite here in Las Vegas and I have some great pictures and new specs to report on this hot board! I was able to have some one on one time with EVGA’s Jacob Freeman and Peter Tan (aka Shamino) and was able to see this new board hands-on (a world first).
First of all, most of you are probably aware of the primary specs that have already been released for the board. These include three phase PWM for each set of memory slots per CPU, industry leading digital PWM for the CPU’s, dual NF200 chips for Quad SLI (and still more lanes free), ICH10R, and high quality solid state capacitors, chokes, and PCB.
Some things you may not know:
The board is able to run with two entirely different models of CPU, or the same CPU’s at different multipliers.
There are two 8 pin, three 6 pin, and two 4 pin floppy connectors in and around the CPU sockets for delivering extra power to the DIMM slots, CPU’s and graphic cards while under extreme overclocking condition. Peter tells me that only the standard 8 pin connectors will be required for most operational circumstances and that only under really serious overclocking will the additional power connectors become necessary.
Peter says the board itself is essentially finished, what is left is BIOS tuning which is still relatively early on and will take a few more weeks to complete.
Board will have two SATA 6GBPS ports on board (red ports), as well as two USB 3.0 on the back IO. Marvel is the chip.
MSRP is still unknown, but I was able to ascertain that it will be between $450 and $550, pricey but to be expected for a board of this caliber and quality.
Expect boards to arrive to the market sometime in April, or possibly later if BIOS tuning takes longer than expected.
*Techreaction*
:icon_super:
Het enige nadeel is dat deze niet met de gewoone i7 cpu's werkt enkel met de Xeon variant
Code:
Het meest unieke aan het bord zijn uiteraard de twee processorsockets, die alleen geschikt zijn voor de Core i7 gebaseerde Intel Xeon processors
Code:
Lijkt me niet echt een probleem, duw je er een Intel Xeon X5570 2x in met een stapeltje dikke GPU's en vervolgens blaas je HW-bot ranking omver :066:
Hou er dan wel rekening mee dat je niet de enige zal zijn...
Je moet trouwens ook nog een nieuwe LSI kaart tellen met 8 (16) x intel SSD om in de PC mark aan de top te komen.
Dual boreas chillers op je Xeons of beter nog Gulfy's (zijn ook al xeons van in omloop kijk maar naar Chiller) en laat die 16 of 24 (!) core's maar rekenen op Pi 32M en de pc mark benches!
Krijg al rillingen als ik er aan denk...:066:
G waterkoeling voor dual xeon (socket 771) fileserver Advies Waterkoeling Setup 8
R Complete dual loop te koop [Hardline] Hoop onderdelen Te Koop 6
Jason Singularity Computers Resonance Single & Dual HighFlow Product Suggesties en Nieuws 0
X MO-RA 360 + Dual Pump bracket Cases en Modding 4
Fryslanboy [WC] Dual System, i5 KabyLake, Z270G en Z270I, 2x GTX10xx Advies Waterkoeling Setup 6
TinusB Single of dual loop Waterkoeling 3
arwin74 Phanteks Dual SSD Bracket HighFlow Product Suggesties en Nieuws 4
Sw333t Phanteks Enthoo Mini XL DS (Dual System) HighFlow Product Suggesties en Nieuws 2
S [EK-FC Terminal DUAL Serial] past niet, alternatieven? Waterkoeling 2
S [EK-FC Terminal DUAL Serial] Rubber ringetje/gasket blijft niet in de groef zitten.. Waterkoeling 4
P Welke Dual bay reservoir met pomp? Advies Waterkoeling Setup 5
R s2011 ... goede/beste blokken voor dual proc Waterkoeling 0
XenoMorpH Welke EK res op de EK-DDC Dual TOP V.2?? Waterkoeling 3
nicvdv EK-FC Bridge DUAL Parallel CSQ Plexi Waterkoeling 2
B EK-FC Bridge DUAL Serial 3-Slot CSQ HighFlow Product Suggesties en Nieuws 2
F [IN-ACTIVE] Bitspower D5 / MCP655 Dual Mod Top/Extreme Verkocht 0
Sw333t XSPC Dual 5.25" Bay Reservoir - Black - Ball Front (BR525DBW) HighFlow Product Suggesties en Nieuws 2
P EK-D5 Dual TOP G1/4 CSQ - Acetal HighFlow Product Suggesties en Nieuws 1
C [IN-ACTIVE] EK-FC Bridge DUAL Parallel CSQ Verkocht 1
psyduck170 plaatsing bitspower dual pump top Overige Koeling 4
E X2O 750 Dual bay pump/res genoeg voor 240 + 360 radiator Waterkoeling 2
R [IN-ACTIVE] GTX 295 dual pcb waterblok Gevonden 15
R Welke Dual Top voor 2x MCP35X? Waterkoeling 1
R Swiftech Maelstrom-35X 5.25 Dual Bay Reservoir with 2x MCP35X housing HighFlow Product Suggesties en Nieuws 6
