Hi Guys,
I hope it's okay to create a post in English.
I'm planing on purchasing the following from Highflow:
Bitspower D5 Mod Kit Black Sparkle
Bitspower D5 MOD TOP - Clear "S" Model - BP-D5TOPACS-BK
Bitspower Dual / Single D5 Top Upgrade Kit 150- Clear BP-D5TOPUK150AC-CLCL
I'm going for the following config to be mounted vertically in a Fractal define S:
I'd like to know what the total height is of this entire configuration. I'm trying to work out whether to purchased the upgrade 150, or 250 but need to know the total installed height?
I'll try to leave another 5-10cm on top clearance so i can access the fill port, and so the look can return to reservoir.
Thanks guys
Thanks guys
