Vandaag weer even geprobeerd, ging ie gelijk updaten en na update zijn alle problemen opgelost
Crysis draait nu met crossfire aan, extreme en 1920x1080 lekker soepel woohoo
Crysis 2 DX11 and High Res Textures Updateinfo:by Cry-Tom Jun 22, 2011 / 11:34
Crysis 2 DX11 and High Res Textures UpdateAs a number of users were able to download the DX11 and High res texture packages from our test environment we would like to take this opportunity to explain how these files will work and our future plans via a short FAQ;
Where can I download these files?
We have removed the files from our websites until the full release date.
How do I install these packs?
Both the DX11 and High Res texture packages require Crysis 2 PC Patch 1.9 to work. Without this patch they cannot be installed.
When will patch 1.9 be available?
Crysis 2 PC patch 1.9 AND the DX11 and High Res Texture packages will be made available on MyCrysis.com on Monday June 27th!
Please note that the files will not work without the PC patch scheduled for release on Monday, more information about this including all download links will be made available to you via MyCrysis.com and our social network pages. If you would like to see a list of changes made in patch 1.9 you can view them HERE.
Below are the patch notes for Patch 1.9, this is also the patch that will enable DX11 Support (available via a separate download). We're aiming to have this patch live and available to you all next week. As always we're interested to hear your comments/thoughts on these changes so please post them below.
Crysis 2 Patch 1.9
• Added Contact Shadows
• Added DX11 benchmark level
• Added DX11 support for Crysis 2 (the following features only work when downloading the optional DX11 package here):
• - Tessellation + Displacement Mapping
• - High Quality HDR Motion Blur
• - Realistic Shadows with Variable Penumbra
• - Sprite Based Bokeh Depth of Field
• - Parallax Occlusion Mapping
• - Particles Motion Blur, Shadows and Art Updates
• - Water Rendering improvements and using Tessellation + Displacement Mapping
• Added Realtime Local Reflections
• Added support for Higher Res Textures Package
• Added various new console variables to whitelist
• Fixed bullet penetration, which had been broken by a bug introduced with the DLC 2 patch
• Fixed issue in MP where player stats weren't always saved at the end of a game
• Fixed issue in MP where player stats would sometimes randomly reset
• Fixed issue with MP time played statistic, which would sometimes be too low on leaderboards and in stats
• Fixed issue with JAW rocket not firing through window's containing broken glass
• Fixed rare issue where a user could not access MP with a valid CD key if they had previously used an invalid CD key
• Improved advanced graphics options menu
• Improved anti-cheat measurements: fixed exploit which could prevent vote kicking working against a user
• Improved multi-GPU support
• Improved Tone Mapping
• Re-added possibility to enable r_StereoSupportAMD via config file (unsupported)
