Tath
Well-known member
Nieuwe reservoirs van Bitspower
BP-WTZMC150AC-CLBK Bitspower Water Tank Z-Multi Compact 150 (Black Acrylic Version
BP-WTZMC200AC-CLBK Bitspower Water Tank Z-Multi Compact 200 (Black Acrylic Version)
BP-WTZMC250AC-CLBK Bitspower Water Tank Z-Multi Compact 250 (Black Acrylic Version)
BP-WTZMC300AC-CLBK Bitspower Water Tank Z-Multi Compact 300 (Black Acrylic Version)
Features:
1. Design For Multi-Function On Water-Tank Issue.
2. The Simple Design For Water Storage.
3. With 3-Way Inlet/Outlet.
4. Unique Design Baffle In Order To Prevent Whirlpool Created.
5. Both Top Made Of Black Acrylic .
6. Tank Body Made Of Hi-Quality Acrylic.
7. RoHS Compliant.
Dimension ( ΦxH ) : 50X150/200/250/300 MM. ( +/-3%)
Thread : G1/4" x 3.
Acrylic Tube Color: Clear.
Included :
1. Z-CAP I Compact With G1/4" x 1 PCS.
2. Z-CAP II Compact With G1/4" x 1 PCS.
3. G1/4" Silver Shining Aqua-Pipe I x 1 PCS
4. Z-Tube Compact 150/200/250/300 x 1 PCS.
5. TANK CLAMP SET II For Z-Multi Compact OD 50MM x 2PCS.
6. G1/4" Crystal Stop Fitting I With 5MM LED Hole x 1PCS.
***All Specification Will Be Changed Without Further Notice***
Features:
7. RoHS Compliant.
Thread : G1/4" x 3.
Included :
