Bitspower NEW Water Tank Z-Multi 150\200\300 (Limited Brass Edition - True Brass)
Tath
Well-known member
Bitspower nieuwe reservoirs Z-Multi 150\ 200\ en 300 (Limited Brass Edition - True Brass)
BP-WTZM150BS-TBLE Water Tank Z-Multi 150 (Limited Brass Edition - True Brass)
BP-WTZM200BS-TBLE Water Tank Z-Multi 200 (Limited Brass Edition - True Brass)
BP-WTZM300BS-TBLE Water Tank Z-Multi 300 (Limited Brass Edition - True Brass)
Features:
1. Design For Multi-Function On Water-Tank Issue.
2. The Simple Design For Water Storage.
3. Both Top Made Of Brass.
4. Tank Body Made Of Hi-Quality Acrylic.
5. RoHS Compliant.
Dimension ( ΦxH ) : 60X150/200/300 MM. ( +/-3%)
Thread : G1/4" x 4.
Acrylic Tube Color: Clear.
Included :
1. BP-TBWP-C06 X 1PCS.
2. BP-TBWP-C17 X 1PCS.
3. BP-TBWP-C46 X 1PCS.
4. BP-ACSTI X 1PCS.
5. BP-TBC4-BK X 2PCS.
***All Specification Will Be Changed Without Further Notice***
coolfris
N Bitspower 300 mm Water Tank HighFlow Product Suggesties en Nieuws 4
Tath Bitspower Water TanK Z-Multi Ultra 50/100/150/200/250 (POM Version) HighFlow Product Suggesties en Nieuws 1
Tath Bitspower Water Tank Z-Multi Compact 150/200/250/300 (Black Acrylic Version) HighFlow Product Suggesties en Nieuws 0
W bitspower water tank z-multi 250 Waterkoeling 2
P [Gezocht] Bitspower Water Tank Z-Multi 250 - Full Clear Acrylic Version BP Gevonden 0
Zwelgje Bitspower Water Tank Z PLUS - POM Version HighFlow Product Suggesties en Nieuws 4
Verderf Bitspower 140mm Water Tank Mount Panel HighFlow Product Suggesties en Nieuws 2
arwin74 [VERKOCHT] Bitspower Water Tank Z-Multi 80 - POM BP-WTZM80P-BK Verkocht 3
Traxtorm Bitspower Water Tank Z-Tube 150mm (Tube) HighFlow Product Suggesties en Nieuws 12
