Target CPU Frequency 3703MHz
Target DRAM Frequency 1290MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Disabled***
CPU Level Up [i7-crazy-3.70G]
Sync Mode [Enabled]
AI Overclock Tuner [Enabled]
OC From CPU level Up [CPU Level Up]
CPU Ratio Setting [23.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Disabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
Intel(R) Virtualiyation Tech [Enabled]
CPU TM Function [Disabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Disabled]
Intel(R) C-STATE Tech [Disabled]
C State package limit setting [Auto] (niet aanwezig)
BCLK Frequency [161]
PCIE Frequency [100]
DRAM Frequency [Auto]
handmatig
UCLK Frequency [Auto]
QPI Link Data Rate [AUTO]
36x? Het laagst, maar geen slow mode
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency 8 [Auto]
6
RAS# to CAS# Delay 8 [Auto]
6
RAS# PRE Time 8 [Auto]
5
RAS# ACT Time 20 [Auto]
18
RAS# to RAS# Delay 4 [Auto]
auto
REF Cycle Time 59 [Auto]
auto
WRITE Recovery Time 8 [Auto]
auto
READ to PRE Time 6 [Auto]
auto
FOUR ACT WIN Time 20 [Auto]
auto
Back-To-BackCAS# Delay 0 [Auto]
auto
Timing Mode 1N [1N]
Round Trip Latency on CHA 52 [AUTO]
auto
Round Trip Latency on CHB 53 [AUTO]
auto
Round Trip Latency on CHC 56 [AUTO]
auto
WRITE To READ Delay(DD) 5 [Auto]
auto
WRITE To READ Delay(DR) 5 [Auto]
auto
WRITE To READ Delay(SR) 14 [Auto]
auto
READ To WRITE Delay(DD) 10 [Auto]
auto
READ To WRITE Delay(DR) 10 [Auto]
auto
READ To WRITE Delay(SR) 10 [Auto]
auto
READ To READ Delay(DD) 7 [Auto]
auto
READ To READ Delay(DR) 6 [Auto]
auto
READ To READ Delay(SR) 4 [Auto]
auto
WRITE To WRITE Delay(DD) 7 [Auto]
auto
WRITE To WRITE Delay(DR) 7 [Auto]
auto
WRITE To WRITE Delay(SR) 4 [Auto]
auto
CPU Differential Amplitude [Auto]
auto
CPU Clock Skew [Auto]
auto
IOH Clock Skew [Auto]
auto
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Auto]
Enable
CPU Voltege OCP [Enabled]
CPU PWM Frequency [Auto]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage 1.343 [Auto]
CPU PLL Voltage 1.812 [Auto]
1.8 of lager indien mogelijk, MAX 1.84V
QPI/DRAM Core Voltage 1.420 [1.437]
QPI niet boven 1.35V!
DRAM Bus Voltage 1.561 [Auto]
1.65V -> mag 1.64 ~ 1.66V voor 1600Mhz 6-6-5-18
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
auto
DRAM CTRL REF Voltage on CHA [Auto]
auto
DRAM DATA REF Voltage on CHB [Auto]
auto
DRAM CTRL REF Voltage on CHB [Auto]
auto
DRAM DATA REF Voltage on CHC [Auto]
auto
DRAM CTRL REF Voltage on CHC [Auto] [auto[/b]
IOH Voltage 1.164 [Auto]
1.10 / 1.20V.
IOH PCIE Voltage 1.508 [Auto]
1.5
ICH Voltage 1.111 [Auto]
1.10
ICH PCIE Voltage [Auto]
1.5
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Auto]
disable
DRAM Spread Spectrum [Auto]
disable
Sommige dingen blank gelaten, Je geheugen moet 6-6-5-18 1T kunnen draaien op ongeveer 1.64V @ 1600Mhz. Dit met QPI voltage (memory controller) op 1.275 ~1.29V.. (te weten:
corsair Dom. GT 2000Mhz)
Het bord ken ik niet, dus je moet gaan spelen. Veel timings van RAM en sommige Voltages op auto zetten.
Succes!
EN leuk dat er nog mensen zijn die je verder ok op weg helpen met goede links! :woot
