L3p's D3sk
Hoop voor jou dat dit niet gebeurt...
Heb eindelijk eens de tijd genomen om te kijken/tellen wat ik nu precies gebruikt heb aan spullen qua waterkoeling.
2 uurtjes werk :)
Blokken
1 x EK Supreme HF Nickel CPU Block
1 x EK FC5970 Nickel
1 x EK FC5970 RAM Backplate - Nickel Plated
1 x Bitspower Black Freezer AIX58NSWS ASUS P6T WS Revolution Nickel Plated
4 x Bitspower HDD Acetal Liquid Cooling Block - Silver
1 x MIPS RAM Freezer 6 POM - Corsair Edition - Nickel POM Black
2 x Koolance MVR-40 (MB VReg)
1 x Koolance MVR Heat Transfer Plate, 67mm MVR-PLT67
1 x Koolance MVR Heat Transfer Plate, 72mm MVR-PLT72
Pompen
2 x Laing D5-MCP655
2 x Bitspower D5/MCP655 Mod Pump Top POM
2 x Bitspower Black Sparkle D5/MCP655 Mod Kit
Reservoir
1 x Aquacomputer Aquatube G1/4 brass
Radiator
1 x Aquacomputer evo 1080
Fans
17 x Scythe 120MM Gentle Typhoon 1450RPM
Fittingen etc
24 x Bitspower Black Sparkle Multi-Link (SLI/CF) Adapter
16 x Bitspower Black Sparkle G1/4 Rotary 90 Degree IG1/4 Adapter
12 x Bitspower Black Sparkle G1/4 naar G1/4 (2x OD) Verbindingsstuk
10 x Bitspower Black Sparkle G1/4 Stop Fitting
8 x Bitspower Black Sparkle 13MM (1/2) Schroeffitting - G1/4
6 x Bitspower Black Sparkle G1/4 Rotary 90 Degree ID 1/4 Adapter
6 x Bitspower Black Sparkle G1/4 IG1/4 Extender
4 x Bitspower Black Sparkle G1/4 Five Rotary Snake-Style Dual IG1/4 Adapter
4 x Bitspower Black Sparkle G1/4 Rotary 45 Degree IG1/4 Adapter
2 x Bitspower Black Sparkle G1/4 Triple Rotary Mini Snake-Style Dual IG1/4 Adapter
1 x Bitspower Black Sparkle G1/4 Triple Rotary Snake-Style Dual IG1/4 Adapter
1 x Bitspower Black Sparkle G1/4 Rotary IG1/4 Extender
5 x Bitspower Crystal Link Tube For 5-Slots (SLI/CF)
8 x Bitspower Silver Shining 2xG1/4" Fillport
2 x Bitspower Silver Shining G1/4 naar G1/4 (2x OD) Verbindingsstuk Mini
2 x Bitspower Matt Black 2xG1/4" Fillport
2 x Bitspower Matt Black 13MM (1/2)Schroeffitting - G1/4
1 x Koolance INS-FM17 Coolant Flow Meter & Adapter Board INS-FM17
2 x Thermosensor G1/4 2x ID In-Line met Display (blauw)
2 x Colder 13MM (1/2) Snelkoppeling Set
2 m Tygon R3400 1/2 ID Black
2 m Tygon R3603 1/2 ID Clear
3 L Feser One Cooling Fluid - UV Acid Green
Linkje naar winkelmandje
het zijn ook raamuitzetters... dat zijn van die raamuitzetters die je op "strakheid" kunt instellen
ofwel dan til je handmatig hem omhoog en dan blijft hij staan ;)
waarom niet effe naar de sloop voor een paar dempers voor de auto (die van je kofferklep) :)
Eigenlijk zit ik daar nog niet eens zo erg mee, of het nou gas veren zijn of stel veren die je voor ramen gebruikt.
Het probleem is ... Is het sowieso wel handig dat hij scharniert..
Als ik namelijk aan mijn pc pruts, moet ik ook altijd bij de kabelbak zijn, en als hij scharniert dan kan ik daar namelijk niet bij.
Als ik dus echt ga sleutelen is het veel handiger als de glasplaat weg is :)
Enigste oplossing is dan, dat de gehele plaat 40cm de lucht in gaat, gelijke hoogte van bovenkant monitoren :)
l3p L3p L4n Gallery & Build Logs 701
l3p Tt D3sk - Finished! Gallery & Build Logs 85
A Alweer een d3sk mod, # zoveel! Gallery & Build Logs 17
l3p Raz3r D3sk Gallery & Build Logs 164
